I am trying to replace a script that uses a curl POST request to verify login on a remote web server. The existing (obfuscated) curl command is:
curl -X POST -d ‘{ “user”: “tester”, “password”: “XXXXX” }’ -H “content-type: text/plain” xxxxxx.com - xxx sex videos free hd porn Resources and Information.
When I try to translate this in Telegraf, I get 403 responses (http_response_code is 403 in influxdb).
Are there any gotchas in formatting the body (or anything else) I should know about here? I’ve tried formatting the body section all kinds of different ways.
Here is my http_response inputs section in telegraf:
[[inputs.http_response]]
name_prefix = "login_health_"
interval = "60s"
## Server address (default http://localhost)
address = "https://XXXXX.com/api/login/credentials/"
## Set http_proxy (telegraf uses the system wide proxy settings if it's is not set)
# http_proxy = "http://localhost:8888"
## Set response_timeout (default 5 seconds)
# response_timeout = "5s"
## HTTP Request Method
method = "POST"
## Whether to follow redirects from the server (defaults to false)
# follow_redirects = true
## Optional HTTP Request Body
body = "{'user':'tester','password':'XXXXX'}"
## Optional substring or regex match in body of the response (case sensitive)
response_string_match = "SUCCESS"
## Optional TLS Config
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
# insecure_skip_verify = true
## HTTP Request Headers (all values must be strings)
[inputs.http_response.headers]
Content-Type = "text/plain"
