Why does the timestamp appear randomly generated when loading data?
Hi!
I have prepared a CSV with the following data.
#datatype measurement,tag,double,double,dateTime:RFC3339
name,building,temperature,humidity,time
iot-devices,5a,72.3,34.1,2024-01-01T12:01:00Z
iot-devices,5a,72.1,33.8,2024-01-02T12:01:00Z
iot-devices,5a,72.2,33.7,2024-01-03T12:01:00Z
(example taken from here > Import CSV Data into InfluxDB Using the Influx CLI and Python and Java Client Libraries | InfluxData)
When I query the data from the data explorer, I see this:
What could be happening?
Thanks a lot!!
I am uploading the data via de InfluxDB CLI for Windows.
Welcome @fabreciano
Can you please post your full query?
hi @grant1 ! I now know what the problem was.
I had a hidden aggregation in the query; possibly included by the query builder.
This is the query I had (it messed up the timestamps):
from(bucket: “PAR_ICA-net-power-data”)
|> filter(fn: (r) => r[“_measurement”] == “iot-devices”)
|> filter(fn: (r) => r[“_field”] == “temperature”)
|> yield(name: “mean”)
and I removed the aggregation part, so it looks like this:
And now, problem solved! Timestamps are OK.
Thanks for reaching out to help!
Fabricio.
Hi @fabreciano
Glad you solved it. I have had the “hidden aggregation” issue as well (I probably also posted on this same forum!) and that is what I suspected was causing the problem.
