/etc/default/chronograf
influxdb
telegraf
kapacitor
Which Linux distribution and version are you running, how did you install the
above applications, and which versions did you install?
Antony.
Thank you for the reply
RHEL - 7.1
Below are the command used
sudo yum localinstall influxdb-1.7.9.x86_64.rpm
sudo yum localinstall telegraf-1.13.1-1.x86_64.rpm
sudo yum localinstall chronograf-1.7.17.x86_64.rpm
sudo yum localinstall kapacitor-1.5.3.x86_64.rpm
Deepthi
