Where to find the DB with FTP [ A way to set the a DB to a other system ]
Dear…
like the head says…
Is there a way for FTP sourcing to a db…
En replace that DB to a other system.
I have system a with a DB for grafana
And i will have this on my system B
Only hope there is a way to do this with FTP and not with CLI.
Thanks.
If I understand correctly that you have a machine running influx with a
database on it and you wish to transfer the contents of that database to
another machien running influx, then I think
Backing up and restoring in InfluxDB OSS | InfluxDB OSS 1.7 Documentation is
what you need.
I really don’t understand the bit about FTP, though. Do people really still
use that these days? I would expect to use rsync on any current machine for
transferring files to/from another one.
Antony.
Thanks for the replay…
And yes Ftp is just login so you can see what you are doing…
And the problem with the link you send…
I use this in 1 lan… and the same 127.0.0.1 server…
So simple is this option not.
Just ftp see the map.
Download it to the pc.
Then the next machine upload the map from the pc…
