I am new to Influxdata.
I’ve created buckets and tried sending data to influxdata. And I can see them in the data explorer.
But , where can I create dashboards ?
I see no buttons or links in my panel .
I am using free plan , with max dashboards = 5 , but … how to create dashboards???
(I am not planned to use grafana for now)
Hello @Smallufo_Huang,
Welcome!
In v3 which is what you’re using we removed dashboards in favor of increased interoperability with other dashboarding tools.
You can use Grafana, Apache Superset, Tableau…etc
Check out these docs on how to leverage each:
If you want just basic visualisation, after logging into InfluxData Cloud portal, go to ‘Data Explorer’ → create your query → Select ‘Graph’ instead ‘Table’ view → Hit ‘Run’. You can also chose between different types of graphs.
