"Public" Local Dashboards
I’m loving the user experience of InfluxDB 2.0, especially in a Docker container. Is there any possibility to make dashboards publically accessible?
I would like to create a dashboard for my data, then be able to serve up a dashboard so that my users can visualize the data without having to log in to the Influx UI.
Cheers,
Heath
Hello @heath,
Not quite what you’re looking for, but have you checked out templates?
Alternatively, did you know that giraffe the visualization library is open source? You can build your visualizations with that if you want too.
Here’s some resources:
Otherwise I recommend creating a feature request here:
Thanks!
