Not able to create Dashboard
I am not using grafana. I wanted to create dashboard with in InfluxDB Cloud Storage Engine Version 3.
This is all I have (I am allowed to have 5 dashbords-- The settings page says “Max Dashboards, 5”):
But I am not able to find the Dashboard icon.
Hello @Fay,
Can you pleaswe share a screenshot of where you’re seeing that on the settings page?
That’s an error. Unfortunately there isn’t any dashboarding toolign with v3. We opted for increased interopability rather than providing dashboarding tools.
You can use:
Hi the settings page does show having the ability of up to 5 dashboards:
Ah thanks @Fay,
Yah that’s a mistake I’ll make sure to share this to the right people. Thank you
i also have the same problem. how do i fix this?
