I’m looking at the “Regex Processor Plugin”: telegraf/README.md at release-1.22 · influxdata/telegraf · GitHub
The example there is not showing anything at all. Other plugins have a diff there, but this is just one single line of Line Protocol.
I know what measurement, tag and field mean for influxdb, but I have never heard of “metric”. What is this, where is the string supposed to be that is being replaced by “metric_rename”
I have tried this to figure out what is going on, but “z”, “y” and “x” are nowhere to be found.
[[processors.converter]]
[processors.converter.tags]
measurement = ["topic"]
[[processors.regex]]
[[processors.regex.tags]]
pattern = ".+"
replacement = "x"
[[processors.regex.fields]]
pattern = ".+"
replacement = "y"
[[processors.regex.field_rename]]
pattern = ".+"
replacement = "v"
[[processors.regex.tag_rename]]
pattern = ".+"
replacement = "w"
[[processors.regex.metric_rename]]
pattern = ".+"
replacement = "z"
_start:time _stop:time _field:string _measurement:string host:string foo_id:string w:string _value:float _time:time
1970-01-01T00:00:00.000000000Z 2022-05-17T13:20:29.175069303Z v foo/1/bar/2/report/telemetry/temperatures/tank 9b391feabbe8 2 1 9314857891347 2022-05-17T13:20:09.929803454Z
