Dear all,
im going crazy to change change a metric name with regex processors.
Im using the below code to change the “metricname” to "metricname_alarms
[[processors.regex]] [[processors.regex.metric_rename]] ## Regular expression to match on an metric name pattern = '([A-Za-z]+)$' ## Replacement expression defining the new name of the metric replacement = '${1}_alarms'
I do not understand why it chnge name but append 3 “_alarms” string to “mtricname”.
Example the metric name is “Hello” and the new metric name is “Hello_alarms_alarms_alarms”
Help!
Your current configuration
matches any alphanumeric characters at the end of the string and adds “_alarms”. When applied again, it matches the alphanumeric part before “_alarms” and adds another “_alarms”, resulting in multiple suffixes.
here are two recommended solutions:
Option 1: Use Two Processors in Sequence
This approach uses the namedrop parameter to exclude metrics that already have the “_alarms” suffix:
# First processor to handle metrics that don't already have _alarms suffix
namepass = ["*"]
# Only process metrics that DON'T end with _alarms
namedrop = ["*_alarms"]
pattern = '^(.+)$'
Option 2: Conditional Logic
Conditional logic in the replacement string:
namepass = ["*"]
pattern = '^(.+)$'
replacement = '''
# Use TOML multi-line string format for embedded logic
if val(".+_alarms$") {
return name
return name + "_alarms"
