Hey guys,
I am new to InfluxDB and Telegraf so I am a bit overwhelmed by everything.
I have a window sensor that is using zigbee to communicate.
Furthermore I have an Zigbee2MQTT Docker container that pushes the messages pushed by the sensor into a topic (homeassistant/rooms/bedroom/window).
I use an MQTT which is also running in a docker container.
Communcation between thos two is okay as I can subscribe to homeassistant/rooms/# and see the message once I close the window contact.
Now I want to use Telegraf to get the messages into InfluxDB. The sensor sends more data than I need so I want to parse it.
Telegraf is configured to listen to homeassistant/rooms/#
Everything seems to work fine as the measurement is correctly parsed and added to my homeassistant bucket with the correct measurement name.
However as I tried to get my hands on the data explorer of my DB (which is also running in a container) I saw many, many measurements. I tried to get a list of them but I did not get it to work with influx cli (I did not even get to get a list of my buckets as I always got an empty list but thats another problem.
Here is a example list of measurements I have in my bucket:
- bedroom (which is the measurement I want to have, with field isWindowClosed)
- boltdb_reads_total
- boltdb_writes_total
- go_gc_duration_seconds
- go_info
- go_memstats_frees_total
- a lot more go_memstats
- http_api_requests_total (and many more http related measurements)
- influxdb_info
- influxdb_remotes_total (many more influx related measurements)
- qc_all_active (and many more qc related measurements)
- service_bucket_new_call_total (many more service related measurements)
- storage_user_new_duration (many more storage related measurements)
- task_scheduler_execute_delta (and some more task related)
I tried to get behind all these but I do not even know where to start.
Is this a Telegraf problem or did I misconfigure something else?
I hope someone could explain to me what is going on.
Thanks in advance,
Tim
