Message:
Jan 09 17:36:58 server1 telegraf[1606]: 2018-01-09T16:36:58Z W! Skipping a scheduled flush because there is already a flush ongoing.
–==Central server==–
grafana-4.6.3-1.x86_64
influxdb-1.4.2-1.x86_64
telegraf-1.5.0-1.x86_64
–==VMs side==–
Configuration of Telegraf: /etc/telegraf/telegraf.conf
[agent]
interval = "15s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "15s"
flush_jitter = "15s"
precision = ""
debug = false
quiet = false
hostname = “”
#logfile = "/var/log/telegraf/telegraf.log"
omit_hostname = false
I’ve read about: interval, flush_interval, flush_jitter recommendation and the things looks like:
Telegraf has a few options you can configure under the [agent] section of the config.
interval: Default data collection interval for all inputs
flush_interval: Default data flushing interval for all outputs. You should not set this below interval. Maximum flush_interval will be flush_interval + flush_jitter
flush_jitter: Jitter the flush interval by a random amount. This is primarily to avoid large write spikes for users running a large number of telegraf instances. ie, a jitter of 5s and flush_interval 10s means flushes will happen every 10-15s.
***In the past I had different values interval: 10s | flush_interval: 10s | flush_jitter: 0s with no problem, now I’m thinking about to change the flush_jitter from 15 to 5s.
Any recommendation?
Kind Regards,
