We’re using prometheus with telegraf.
Using telegraf with following configuration:
interval = “15s”
round_interval = true
flush_interval = “15s”
But there are some metrics whose values are not available in some of the intervals. The poll interval for prometheus is 15 seconds.
This is my understanding: round_interval = true => instructs input to work on clock cycle (00, 15, 30, 45) for above config
flush_interval is the time at which Go’s telegraf.Metric channel buffers are flushed.
Channels buffer size is 100 as per code(agent.go).
Now to encounter the issue, I wish to use flush_interval values to be 2s(frequently providing input data to output, 2s here). Is this the correct solution?
Is there any other implication in lowering flush_interval’s value ?
We’re also using statsd input plugin
