ValueError: cannot convert float NaN to integer
Hi there,
When querying data with python influxDB client to pandas dataframe I get the error message ValueError: cannot convert float NaN to integer.
.venv\Lib\site-packages\influxdb_client\client\flux_csv_parser.py", line 288, in _to_value
  • return int(str_val)*
Is there a solution or workaround for this problem?
Best regards,
Jan
Hello @JanD,
Can you share your python script? (including the flux query?)
As well as the python client version you’re using?
Thank you!
Hello Anaisdg,
Thanks for your interest. Attached you find the python script and below the query.
I use the latest release of the python influxdb_client.
Best regards,
The query i run is:
import “experimental/date/boundaries”
import “influxdata/influxdb/schema”
lastWeek = boundaries.week(week_offset: -1)
from(bucket: “claire-test-data”)
(Attachment download_data.py is missing)
Hello Anaisdg,
Thanks for your interest. Below you find the python script and below the query.
Best regards,
Jan
The python script:
import os
import time
from dotenv import load_dotenv
from influxdb_client import InfluxDBClient
import pandas as pd
import matplotlib
import certifi
import re
For windows ssh certification keys
fh = open(certifi.where(), “r”)
cert = fh.read()
fh.close()
load secret data from .env file
load_dotenv()
token = os.getenv(‘TOKEN’)
org = os.getenv(‘ORG’)
bucket = os.getenv(‘BUCKET’)
host = os.getenv(‘INFLUXDB_HOST’)
Init influxDB client
client = InfluxDBClient(url=host, org=org, token=token)
query_api = client.query_api()
read excel with MAC adresses in pandas dataframe
location_data = pd.read_excel(‘./sensor_locations.xlsx’)
mac_adresses_to_filter = ‘’
for i in range(1,location_data.shape[0]):
if location_data.Active[i] == True:
mac_adresses_to_filter += f’|{location_data.MAC_adresses[i]}’
print( f’MACS {mac_adresses_to_filter}')
query in flux language
start_time = ‘2023-12-20T00:00:00’
stop_time = ‘2023-12-20T23:59:59’
filter_string =“AM232X_RH|AM232X_TEMP|ENS210_RH|ENS210_TEMP|NDIR_CO2|NUMPM0|NUMPM1|NUMPM2|NUMPM4|NUMPM10|PM1|PM2.5|PM4|PM10|IAQ|TVOC”
keep_column_string = ‘[“_time”, “MAC”, "’ + re.sub(‘[|]’, ‘", "’, filter_string) + ‘"]’
query = f’‘’
// Flux query to download data from last week for sensor with MAC adress … /
range(start: {start_time}Z, stop: {stop_time}Z)
filter(fn: (r) => r._measurement == “environment”)
filter(fn: (r) => r.MAC =~ /^({mac_adresses_to_filter})$/)
filter(fn: (r) => r._field =~ /^({filter_string})$/)
pivot(rowKey:[“_time”], columnKey: [“_field”], valueColumn: “_value”)
group()
keep(columns: {keep_column_string})
print(query)
Run query and return data as pandas data frame
data = query_api.query_data_frame(query=query)
print(data.head())
close client
client.close()
csv_filename = f’AC_data_{start_time}{stop_time}.csv’
pk1_filename = f’../Data_archive/AC_data
{start_time}{stop_time}.pk1.zip’.replace(‘:’,'‘)
zip_archive_filename = f’../Data_archive/AC_data_{start_time}_{stop_time}all.zip’.replace(‘:’,'')
print(zip_archive_filename)
print(csv_filename)
save data as compressed csv
data.to_csv(zip_archive_filename, sep=‘,’, compression={‘method’: ‘zip’, ‘archive_name’: f’{csv_filename}'}, mode=‘a’)
save data as pickle file format
data.to_pickle(pk1_filename, compression=‘zip’)
The query i run is:
Any news about this ?
Not Yet. I made a workaround by saving data first in csv file and then read the CSV in a pandas dataframe.
Best regards,
Jan
