Map function python error
I’m trying to convert _time column into int (or uint) while querying through python client library but I’m getting the error
Traceback (most recent call last):
  File "/home/ubuntu/python/push/push.py", line 62, in <module>
    run()
  File "/home/ubuntu/python/push/push.py", line 57, in run
    read_tables()
  File "/home/ubuntu/python/push/push.py", line 44, in read_tables
    tables = client.query_api().query('''import "strings"
KeyError: 'r with _time'
The piece of code is:
def read_tables():
                                         from(bucket:"test")
                                         |> range(start: -{window_str}s)
                                         |> filter(fn: (r) => strings.hasPrefix(v: r._measurement, prefix: "WO"))
                                         |> map(fn: (r) => ({r with _time: int(v: r._time)}))
                                         |> drop(columns: ["_start", "_stop"])'''
                                         .format(window_str = window))
What I’m I doing wrong?
Thank you!
@fgarcia It looks like this error is coming from the client and not from Flux itself. I’m guessing that the Python client expects the _time column to be a time type. Try mapping the int/uint version of the timestamp to a different column.
def read_tables():
                                         from(bucket:"test")
                                         |> map(fn: (r) => ({r with time_int: int(v: r._time)}))
Hi Scott,
Thank you for your help, unfortunately it did not work either.
I get the same error even if I try with “_value” column
def read_tables():
                                         from(bucket:"test")
                                         |> map(fn: (r) => ({r with _value: int(v: r._value)}))
My bad!
Python code should be:
def read_tables():
                                         from(bucket:"test")
                                         |> map(fn: (r) => ({{r with _time: int(v: r._time)}}))
Double curly braces…
Thank you again!
