Hi to all, i have installed Telegraf, influx and grafana on docker for import data and create a dashboard.
now i need run a script for import json data to influx, but on telegraf i recived this error:
E! error loading config file /etc/telegraf/telegraf.conf: error parsing imput, undefined but requested input: imput
this the telegraf config
[global_tags]
[agent]
interval = "60s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = "telegraf"
omit_hostname = false
[[outputs.influxdb]]
urls = ["http://192.168.1.11:8086"]
database = "influx"
timeout = "5s"
username = "telegraf"
password = "pswwww"
[[inputs.cpu]]
percpu = true
totalcpu = true
collect_cpu_time = false
report_active = false
[[inputs.disk]]
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "iso9660", "overlay", "aufs", "squashfs"]
[[inputs.mem]]
[[inputs.processes]]
[[imput.exec]]
commands = ["/home/manuel/run.sh"]
data_format = "influx"
this the run.sh
#!/bin/bash
# Configuration
ORG="organi"
KEY="key"
SEC="secuekey"
API="https://api2.nicehash.com" #prod env
#API="https://api-test.nicehash.com" # test env
# Command
NHCLIENT="python nicehash.py -b $API -o $ORG -k $KEY -s $SEC"
# Run method
eval "$NHCLIENT -m GET -p '/main/api/v2/mining/rigs/activeWorkers'"; # -b '{json}'
and this the py script
from datetime import datetime
from time import mktime
import uuid
import hmac
import requests
import json
from hashlib import sha256
import optparse
import sys
class public_api:
def __init__(self, host, verbose=False):
self.host = host
self.verbose = verbose
def request(self, method, path, query, body):
url = self.host + path
if query:
url += '?' + query
if self.verbose:
print(method, url)
s = requests.Session()
if body:
body_json = json.dumps(body)
response = s.request(method, url, data=body_json)
else:
response = s.request(method, url)
if response.status_code == 200:
return response.json()
elif response.content:
raise Exception(str(response.status_code) + ": " + response.reason + ": " + str(response.content))
else:
raise Exception(str(response.status_code) + ": " + response.reason)
def get_current_global_stats(self):
return self.request('GET', '/main/api/v2/public/stats/global/current/', '', None)
def get_global_stats_24(self):
return self.request('GET', '/main/api/v2/public/stats/global/24h/', '', None)
def get_active_orders(self):
return self.request('GET', '/main/api/v2/public/orders/active/', '', None)
def get_active_orders2(self):
return self.request('GET', '/main/api/v2/public/orders/active2/', '', None)
def buy_info(self):
return self.request('GET', '/main/api/v2/public/buy/info/', '', None)
def get_algorithms(self):
return self.request('GET', '/main/api/v2/mining/algorithms/', '', None)
def get_markets(self):
return self.request('GET', '/main/api/v2/mining/markets/', '', None)
def get_currencies(self):
return self.request('GET', '/main/api/v2/public/currencies/', '', None)
def get_multialgo_info(self):
return self.request('GET', '/main/api/v2/public/simplemultialgo/info/', '', None)
def get_exchange_markets_info(self):
return self.request('GET', '/exchange/api/v2/info/status', '', None)
def get_exchange_trades(self, market):
return self.request('GET', '/exchange/api/v2/trades', 'market=' + market, None)
def get_candlesticks(self, market, from_s, to_s, resolution):
return self.request('GET', '/exchange/api/v2/candlesticks', "market={}&from={}&to={}&resolution={}".format(market, from_s, to_s, resolution), None)
def get_exchange_orderbook(self, market, limit):
return self.request('GET', '/exchange/api/v2/orderbook', "market={}&limit={}".format(market, limit), None)
class private_api:
def __init__(self, host, organisation_id, key, secret, verbose=False):
self.key = key
self.secret = secret
self.organisation_id = organisation_id
self.host = host
xtime = self.get_epoch_ms_from_now()
xnonce = str(uuid.uuid4())
message = bytearray(self.key, 'utf-8')
message += bytearray('\x00', 'utf-8')
message += bytearray(str(xtime), 'utf-8')
message += bytearray(xnonce, 'utf-8')
message += bytearray(self.organisation_id, 'utf-8')
message += bytearray(method, 'utf-8')
message += bytearray(path, 'utf-8')
message += bytearray(query, 'utf-8')
if body:
message += bytearray(body_json, 'utf-8')
digest = hmac.new(bytearray(self.secret, 'utf-8'), message, sha256).hexdigest()
xauth = self.key + ":" + digest
headers = {
'X-Time': str(xtime),
'X-Nonce': xnonce,
'X-Auth': xauth,
'Content-Type': 'application/json',
'X-Organization-Id': self.organisation_id,
'X-Request-Id': str(uuid.uuid4())
s.headers = headers
if query:
url += '?' + query
if self.verbose:
print(method, url)
if body:
else:
else:
def get_epoch_ms_from_now(self):
now = datetime.now()
now_ec_since_epoch = mktime(now.timetuple()) + now.microsecond / 1000000.0
return int(now_ec_since_epoch * 1000)
def algo_settings_from_response(self, algorithm, algo_response):
algo_setting = None
for item in algo_response['miningAlgorithms']:
if item['algorithm'] == algorithm:
algo_setting = item
if algo_setting is None:
raise Exception('Settings for algorithm not found in algo_response parameter')
return algo_setting
def get_accounts(self):
return self.request('GET', '/main/api/v2/accounting/accounts2/', '', None)
def get_accounts_for_currency(self, currency):
return self.request('GET', '/main/api/v2/accounting/account2/' + currency, '', None)
def get_withdrawal_addresses(self, currency, size, page):
params = "currency={}&size={}&page={}".format(currency, size, page)
return self.request('GET', '/main/api/v2/accounting/withdrawalAddresses/', params, None)
def get_withdrawal_types(self):
return self.request('GET', '/main/api/v2/accounting/withdrawalAddresses/types/', '', None)
def withdraw_request(self, address_id, amount, currency):
withdraw_data = {
"withdrawalAddressId": address_id,
"amount": amount,
"currency": currency
return self.request('POST', '/main/api/v2/accounting/withdrawal/', '', withdraw_data)
def get_my_active_orders(self, algorithm, market, limit):
ts = self.get_epoch_ms_from_now()
params = "algorithm={}&market={}&ts={}&limit={}&op=LT".format(algorithm, market, ts, limit)
return self.request('GET', '/main/api/v2/hashpower/myOrders', params, None)
def create_pool(self, name, algorithm, pool_host, pool_port, username, password):
pool_data = {
"name": name,
"algorithm": algorithm,
"stratumHostname": pool_host,
"stratumPort": pool_port,
"username": username,
"password": password
return self.request('POST', '/main/api/v2/pool/', '', pool_data)
def delete_pool(self, pool_id):
return self.request('DELETE', '/main/api/v2/pool/' + pool_id, '', None)
def get_my_pools(self, page, size):
return self.request('GET', '/main/api/v2/pools/', '', None)
def get_hashpower_orderbook(self, algorithm):
return self.request('GET', '/main/api/v2/hashpower/orderBook/', 'algorithm=' + algorithm, None )
def create_hashpower_order(self, market, type, algorithm, price, limit, amount, pool_id, algo_response):
algo_setting = self.algo_settings_from_response(algorithm, algo_response)
order_data = {
"market": market,
"amount": amount,
"price": price,
"limit": limit,
"poolId": pool_id,
"type": type,
"marketFactor": algo_setting['marketFactor'],
"displayMarketFactor": algo_setting['displayMarketFactor']
return self.request('POST', '/main/api/v2/hashpower/order/', '', order_data)
def cancel_hashpower_order(self, order_id):
return self.request('DELETE', '/main/api/v2/hashpower/order/' + order_id, '', None)
def refill_hashpower_order(self, order_id, amount):
refill_data = {
"amount": amount
return self.request('POST', '/main/api/v2/hashpower/order/' + order_id + '/refill/', '', refill_data)
def set_price_hashpower_order(self, order_id, price, algorithm, algo_response):
price_data = {
"price": price,
return self.request('POST', '/main/api/v2/hashpower/order/' + order_id + '/updatePriceAndLimit/', '',
price_data)
def set_limit_hashpower_order(self, order_id, limit, algorithm, algo_response):
limit_data = {
"limit": limit,
limit_data)
def set_price_and_limit_hashpower_order(self, order_id, price, limit, algorithm, algo_response):
price_data = {
"price": price,
"limit": limit,
price_data)
def get_my_exchange_orders(self, market):
return self.request('GET', '/exchange/api/v2/myOrders', 'market=' + market, None)
def get_my_exchange_trades(self, market):
return self.request('GET','/exchange/api/v2/myTrades', 'market=' + market, None)
def create_exchange_limit_order(self, market, side, quantity, price):
query = "market={}&side={}&type=limit&quantity={}&price={}".format(market, side, quantity, price)
return self.request('POST', '/exchange/api/v2/order', query, None)
def create_exchange_buy_market_order(self, market, quantity):
query = "market={}&side=buy&type=market&secQuantity={}".format(market, quantity)
def create_exchange_sell_market_order(self, market, quantity):
query = "market={}&side=sell&type=market&quantity={}".format(market, quantity)
def cancel_exchange_order(self, market, order_id):
query = "market={}&orderId={}".format(market, order_id)
return self.request('DELETE', '/exchange/api/v2/order', query, None)
if __name__ == "__main__":
parser = optparse.OptionParser()
parser.add_option('-b', '--base_url', dest="base", help="Api base url", default="https://api2.nicehash.com")
parser.add_option('-o', '--organization_id', dest="org", help="Organization id")
parser.add_option('-k', '--key', dest="key", help="Api key")
parser.add_option('-s', '--secret', dest="secret", help="Secret for api key")
parser.add_option('-m', '--method', dest="method", help="Method for request", default="GET")
parser.add_option('-p', '--path', dest="path", help="Path for request", default="/")
parser.add_option('-q', '--params', dest="params", help="Parameters for request")
parser.add_option('-d', '--body', dest="body", help="Body for request")
options, args = parser.parse_args()
private_api = private_api(options.base, options.org, options.key, options.secret)
params = ''
if options.params is not None:
params = options.params
try:
response = private_api.request(options.method, options.path, params, options.body)
except Exception as ex:
print("Unexpected error:", ex)
exit(1)
print(response)
exit(0)
