How to use refer column names using r.sourceProcessed and r.targetProcessed ? The processed variables are exact same as the column name.
sourceProcessed = processStatusName(status: source)
targetProcessed = processStatusName(status: target)
from(bucket: bucket)
|> range(start: startRange, stop: now())
|> filter(fn: (r) => r._field == sourceProcessed or r._field == targetProcessed)
|> filter(fn: (r) => r.sourceProcessed != "" and r.targetProcessed != "")
|> map(fn: (r) => {
diffSeconds = float(v: int(v: r.targetProcessed) - int(v: r.sourceProcessed))
time_diff = diffSeconds / 86400.0
return {_time: r._time, time_diff: time_diff}
|> group(columns: ["_start", "_stop"])
|> mean(column: "time_diff")
|> yield(name: "mean_time_diff")
This issue occurs only in bottom part. Following query works without throwing any errors.
Any ideas to fix this? TIA!
