With Flux language syntex, how tu rename column name in result tables? Like “as name” in sql “select n1 as name from …”.
eg.
from(bucket: “${bucket}”)
|> range(start: v.timeRangeStart)
|> filter(fn: (r) => r.host == “${host}”)
|> filter(fn: (r) => r._measurement == “mem”)
|> filter(fn: (r) => r._field == “used_percent” or r._field == “cached” or r._field == “free” or r._field == “buffered”)
| > yield(name: “mean”) |
| In above query, I want to change “used_percent” “cached” to something else in order to modify the column names in the data output and affect the names of the legend. |
I’m not knowledgeable in Flux, so I’ll tell you how you can do that on Grafana itself.
You can use the Organize fields transform to reorder and rename columns/fields
