Unexpected string"\n" shown in my field values
Hi everyone! I’m new to InfluxDB and I’m trying to input data from .csv file using Python api. My code worked without problems but I notice that there was an unexpected string"\n" at the end of each of my data.
I don’t know exactly why this issue came out. Any suggestion would be helpful for me. Thank you.!
My code is as follows:
import datetime
import random
import time
import os
import csv
from csv import reader
import argparse
from influxdb import client as influxdb
client = influxdb.InfluxDBClient(host = ‘localhost’, port = 8086)
client.create_database(‘test_xufu’)
#print(client.get_list_database())
client.switch_database(‘test_xufu’)
def read_data(filename):
with open(filename) as f:
lines = f.readlines()[1:]
return lines
if name == ‘main’:
filename = r’/Users/chenayu/Desktop/test_xufu1.csv’
lines = read_data(filename)
for rawline in lines:
line = rawline.split(’,’)
dt = line[0]
json_body = [
“measurement”: “load”,
“tags”:{
“host”: “Xufu”,
“region”: “Lianyungang”
“time”: dt,
“fields”:{
“load”: line[1],
client.write_points(json_body)
And my data is listed as follows:
Well I think I’d better attach a screenshot of my code:
