I setup telegraf on Windows server. I am able to run it stand-alone and as a service. I need to parse an array of JSON strings to influx db. The python code is executing, but the plug-in throws a parse error as below:
- Plugin: inputs.exec, Collection 1
- Internal: 10s
2017-12-22T20:21:00Z E! Error in plugin [inputs.exec]: unable to parse out as JS
ON, invalid character ‘H’ looking for beginning of value
Here is the .conf file:
[[inputs.exec]]
command = "stats.py"
data_format = "json"
name_override = "response_time"
interval = "10s"
tag_keys = ["request","site","stype"]
[[outputs.influxdb]]
urls = ["udp://127.0.0.1:8089"]
database = "test" # required
precision = "s"
timeout = "5s"
The json format I need to use to parse to influxdb as below:
[{‘requestStat’: {‘count’: 20000, ‘min’: 0.0, ‘max’: 1700, ‘avg’: 147.617232}, ‘request’: ‘/login.aspx’, ‘site’: ‘X’, ‘stype’: ‘XY’}, {‘requestStat’: {‘count’: 157588, ‘min’: 0.0, ‘max’: 143654.0, ‘avg’: 216.54604411503414, ‘sum’: 34125058.0}, ‘request’: ‘/default.aspx’, ‘site’: ‘X’, ‘stype’: ‘XY’}]
Please advise
