I’ve had to make a recent change to my Telegraf collector, to reduce the SNMP load on a new switch, as its ifXTable was returning data for over 200 virtual interfaces (on a 24 port switch) hammering the CPU.
With the below configuration, I can get switch traffic into InfluxDB, while dropping the virtual interfaces from being saved.
However, I’m only able to retrieve data if I do not specify an interface.
I suspect that it’s because I’ve enabled ifName as a tag (see config at the end of this post), but I can’t get it to work with or without it. Can anyone please shed some light on what I’m doing wrong?
SELECT derivative(mean("ifHCInOctets"), 1s) /1000000*8 AS "In", derivative(mean("ifHCOutOctets"), 1s) /1000000 *-8 AS "Out" FROM "snmp" WHERE ("hostname" = 'Server-Room-C-POE') AND $timeFilter GROUP BY time($interval), "ifName" fill(null)
vs specifying an ‘ifName’ interface in the the following query returns no data.
SELECT derivative(mean("ifHCInOctets"), 1s) / 1000000 *8 AS "Down", derivative(mean("ifHCOutOctets"), 1s) / 1000000 *-8 AS "Up" FROM "snmp" WHERE ("hostname" = 'Server-Room-C-POE' AND "ifName" = 'gi1/0/1') AND $timeFilter GROUP BY time($__interval) fill(null)
Here’s the relevant snmp collector section in my telegraf agent
## measurement name
name = "snmp"
[[inputs.snmp.field]]
name = "hostname"
oid = "RFC1213-MIB::sysName.0"
is_tag = true
[[inputs.snmp.table]]
name = "snmp"
inherit_tags = [ "hostname" ]
# Not collecting the below table as switch returns 4000+ rows due to unneeded virtual interfaces being included
# oid = "IF-MIB::ifXTable"
[[inputs.snmp.table.field]]
name = "ifName"
oid = "IF-MIB::ifName"
is_tag = true
name = "ifHCOutOctets"
oid = ".1.3.6.1.2.1.31.1.1.1.10"
name = "ifHCInOctets"
oid = ".1.3.6.1.2.1.31.1.1.1.6"
oid = "IF-MIB::ifOperStatus"
is_tag = true
#Other collected fields
name = "PoEConsumedPower"
oid = ".1.3.6.1.2.1.105.1.3.1.1.4.1"
name = "CPU 1s"
oid = ".1.3.6.1.4.1.9.6.1.101.1.7.0"
name = "CPU 1m"
oid = ".1.3.6.1.4.1.9.6.1.101.1.8.0"
name = "CPU 5m"
oid = ".1.3.6.1.4.1.9.6.1.101.1.9.0"
#Dropping the virtual interfaces reported as "Not Present"
[inputs.snmp.tagdrop]
ifOperStatus = ["6"]
