Unable to get SNMP , telegraf & influxdb
hello im trying to monitor my meraki MR wireless devices using grafana , influxdb a, telegraf , i did set up all good ,
im able to snmpwalk snmp. meraki .com is OK !
but when runing :
systemctl status telegraf
i get :
[admin@centos-local ~]$ systemctl status telegraf
May 28 23:41:40 centos-local telegraf[108467]: 2021-05-28T22:41:40Z E! [inputs.snmp] Error in plugin: agent sn mp.meraki.com: performing get on field hostname: request timeout (after 3 retries)
May 28 23:41:50 centos-local telegraf[108467]: 2021-05-28T22:41:50Z W! [inputs.snmp] Collection took longer than expected; not complete after interval of 10s
or
gathering table snmp: performing bulk walk for field ifName: reque>
PS: when using acess point local ip’s its works fine
i dont know what is the issue
my telegraph .conf
[[inputs.snmp]]
agents = [ “snmp.mraki.com” ]
version = 2
community = “*******”
name = “snmp”
[[inputs.snmp.field]]
name = “hostname”
oid = “RFC1213-MIB::sysName.0”
is_tag = true
[[inputs.snmp.table]]
name = “snmp”
inherit_tags = [ “hostname” ]
oid = “IF-MIB::ifTable”
[[inputs.snmp.table.field]]
  name = "ifName"
  oid = "IF-MIB::ifName"
  is_tag = true
thanks
This looks similar to SNMP plugin timeout when the response SRC IP is different than original request (HA Virtual IPs) · Issue #3320 · influxdata/telegraf · GitHub and thus Input SNMP not parsing results from Cisco WLC properly. · Issue #6353 · influxdata/telegraf · GitHub which appears to be fixed, but you’re seeing similar behaviour. Is there an HA environment failing over, or maybe traffic going to the wrong destination?
