HI There,
I have installed the influxDB on my local and i am using the below python code to write the data into influxDB. I was able to access the UI on http://localhost:8086. and i was able to ping it. However, when i run the code, i am getting unauthorized error. Any help would be appreciated.
123123:~ peter$ influx ping
OK
from influxdb import InfluxDBClient
from datetime import datetime
client = InfluxDBClient('localhost', 8086, 'username', 'password', 'database_name')
client.create_database('database_name')
client.get_list_database()
client.switch_database('database_name')
# Inserting data into InfluxDB each row at a time
print("InfluxDB injection process started.")
for row in df.iterrows():
influxJson = [
"measurement":"test7",
"time" : datetime.utcnow().isoformat() + "Z",
"tags": {
'ResiliencyTier':'targetResiliencyTier',
'lob' : 'teacher'
"fields": {
columns[0][0] : str(row[1][0]),
columns[1][0] : str(row[1][1])
client.write_points(influxJson)
print("process completed.")
startProcess()
Error:
Traceback (most recent call last):
File "/Users/peter/Library/Python/3.8/lib/python/site-packages/influxdb/client.py", line 378, in request
raise InfluxDBClientError(err_msg, response.status_code)
influxdb.exceptions.InfluxDBClientError: 401: {"code":"unauthorized","message":"Unauthorized"}
Thank You
