'm new to InfluxDB and encountering an “unauthorized access” issue when trying to connect to my InfluxDB instance using the Python influxdb library. I’m receiving the following error message: Reason: Unauthorized HTTP response headers: HTTPHeaderDict({'Content-Type': 'application/json; charset=utf-8', 'X-Influxdb-Build': 'OSS', 'X-Influxdb-Version': 'v2.7.0', 'X-Platform-Error-Code': 'unauthorized', 'Date': 'Wed, 17 May 2023 15:03:50 GMT', 'Content-Length': '55'}) HTTP response body: {"code":"unauthorized","message":"unauthorized access"}
Code Snippet that I tried from the InfluxDB documentation to connect using the python client library, was trying this to get familiar with the process :
import influxdb_client, os, time
from influxdb_client import InfluxDBClient, Point, WritePrecision
from influxdb_client.client.write_api import SYNCHRONOUS
token = os.environ.get("INFLUXDB_TOKEN")
org = "Org_Name"
url = "http://localhost:8086"
write_client = influxdb_client.InfluxDBClient(url=url, token=token, org=org)
bucket="SensorDB"
write_api = write_client.write_api(write_options=SYNCHRONOUS)
for value in range(5):
point = (
Point("measurement1")
.tag("tagname1", "tagvalue1")
.field("field1", value)
write_api.write(bucket=bucket, org="Org_Name", record=point)
time.sleep(1) # separate points by 1 second
What could be the cause of this error, and how can I resolve it?
Any guidance or suggestions would be greatly appreciated. Thank you!
