Python influxdb bucket connection
sorry Iam so frustated sitting so long on this propaly stupid issue.
I have a Sensor, which data I would like to upload to my bucket created on influxdb
CODE
#!/usr/bin/python
# -*- coding:utf-8 -*-
from datetime import date
REF = 5.08
import influxdb_client, os, time
from influxdb_client import InfluxDBClient, Point, WritePrecision
from influxdb_client.client.write_api import SYNCHRONOUS
bucket = "SkyCamLA"
token = os.environ.get("INFLUXDB_TOKEN")
org = "paulmatteschk@googlemail.com"
url = "https://europe-west1-1.gcp.cloud2.influxdata.com"
client = influxdb_client.InfluxDBClient(url=url, token=token, org=org)
while True:
    SolarIrradiance = (ADC_Value[0] * REF / 0x7fffffff)
               print("ADC1 IN%d = %lf" %(0, (ADC_Value[0] * REF / 0x7fffffff)))   # 32bit
                write_api = client.write_api(write_options=SYNCHRONOUS)
                p = influxdb_client.Point("my_measurement").tag("location", "Laubegast").field("DNH",
                SolarIrradiance)
                write_api.write(bucket=bucket, org=org, record=p)
                time.sleep(40)
ERROR
  File "/home/pi/.local/lib/python3.9/site-packages/influxdb_client/_sync/rest.py", line 243, in request
    raise ApiException(http_resp=r)
influxdb_client.rest.ApiException: (401)
Reason: Unauthorized
HTTP response headers: HTTPHeaderDict({'Date': 'Mon, 25 Jul 2022 10:57:15 GMT', 'Content-Type': 'application/json; charset=utf-8', 'Content-Length': '55', 'Connection': 'keep-alive', 'trace-id': 'bad35e71b8e0d1f5', 'trace-sampled': 'false', 'x-platform-error-code': 'unauthorized', 'Strict-Transport-Security': 'max-age=15724800; includeSubDomains', 'X-Influxdb-Request-ID': '5583707876ff46d48ed7476f999c9ba1', 'X-Influxdb-Build': 'Cloud'})
HTTP response body: {"code":"unauthorized","message":"unauthorized access"}
in /etc/influxdb/influxdb.config is http true…
I dont get it
Hi @Bra1nsen,
You are using INFLUXDB_TOKEN system environment variable to set authorisation token. Do you have correctly set this system variable?
Regards
good point, i did as described:
“export INFLUXDB_TOKEN=pMa7…”
but its not showing in printenv
ok it works after entering the token manually in the python script.
Do you know how to set up the environment var correct in linux?
You have to add the export of the INFLUXDB_TOKEN to your ~/.bashrc.
youre my hero, thanks alot bednar
