UDP send data to InfluxDb2
Hello dear members,
I have a setup / system setup questions
I have already installed
-Centos8
-InfluxDb2
-Telegraf
What i want
Getting data form my PLC to influx
In my PLC i have setup a UDP connection to send data to influx
The data will be send about every 5 seconds.
This UDP packet contains
1 Tag-1, Value : 34.7893 ( real)
2 Tag-2, Value : True/False
3 Tag-3, Value : String/chars
4 Tag-4–50 , Value :123 etc tetc
So about 50 tag per UDP message.
I have already decided that influxdb will take care of the timestamping
So the question
Send directly to InfluxDb or do i need a telegraf plugin ?
Is Influxdb send a conformation/responce back on UDP messages ?
Iám very new to influxdb and do not have read all docs and maybe someone can point me to the right 1.
Send it to your Telegraf instance and use the inputs.socket_listener plugin, which also supports UDP protocol. There is no response for received UDP packets.
Thx Franky1
I have it working now in Influx1.8 and wil soon move it to the new V2 machine.
I have 1 question
I’am sending data to the telegraf Line protocol, iám also sending the timestamp in ms format.
I switched in the agent the precision to “ms”
Only the messages are not being accepted in telegraf, only when i add 000000 zero’s o my timestamp it works. So it is woking but gives a little more data and work on my PLC.
Can telegraf only work with ns format?
