I am having issues with one particular host running telegraf. Issue is related to udp_payload setting.
Sending metrics to influxdb.output, where the InfluxDB output is udp does not work.
There are >10 other hosts running with the same config that do not face the issue.
The telegraf config is:
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
# Add randomness for sending data from all agents
collection_jitter = “1s”
flush_interval = “10s”
debug = true
quiet = false
omit_hostname = false
[[outputs.influxdb]]
urls = [ “udp://hostname:8089” ]
database = "vac"
write_consistency = "any"
timeout = "5s"
udp_payload=65000
InfluxDB udp input is:
[[udp]]
enabled = true
bind-address = ":8089"
database = “vac”
\ # retention-policy = ""
batch-size = 5000
batch-pending = 10
batch-timeout = "1s"
read-buffer = 0
What I’ve tried and works:
- writing the metrics to a file
- writing the metrics to the http endpoint of the same InfluxDB
- writing a metric with netcat from the troublesome host to the UDP endpoint of InfluxDB
What I did find out while randomly playing with the settings is that when I set udp_payload to the default metrics started coming into InfluxDB, and increasing it up to 1500 works.
Does anyone have any pointers into what might be wrong here?
telegraf version: 1.3.3
InfluxDB version: 1.2.1
