Hi Team,
Actually i’m trying to monitor the jenkins website status whether it is up or down or 200 .
For this I configured in telegraf plugin metrics as below
`[[inputs.http_response]]
# ## Deprecated in 1.12, use 'urls'
# ## List of urls to query.
name_override = "status_url"
urls = ["https://info-jenkins.com", "https://info-jenkins1.com" ]
response_timeout = "5s"
# ## HTTP Request Method method = "GET"
###interval = "30s"
# ## Whether to follow redirects from the server (defaults to false)
follow_redirects = true`
Now when i’m trying to fetch the url status from grafana . Some webistes status showing me as 403 status code and some showing as 200 status-code .and i’m able to access the website url also .can anyone help me with this .
note : to login to the jenkins url website i need to enter the SSO credentials .
Input plugin metric -
# ## Server address (default [http://localhost](http://localhost/))
# # address = "[http://localhost](http://localhost/)"
urls = ["[https://url.com](https://url.com/)", "[https://url.com](https://url.com/)"]
# # # HTTP Request Method method = "GET"
###interval = "30s"
# ## Whether to follow redirects from the server (defaults to false) follow_redirects = true
Output of telegraf debug
telegraf -config /etc/telegraf/telegraf.conf -input-filter http_response -test
2024-02-12T15:30:21Z I! Starting Telegraf 1.21.2
2024-02-12T15:30:21Z I! Loaded inputs: http_response
2024-02-12T15:30:21Z I! Loaded aggregators:
2024-02-12T15:30:21Z I! Loaded processors:
2024-02-12T15:30:21Z W! Outputs are not used in testing mode!
2024-02-12T15:30:21Z I! Tags enabled: host=hostname
status_url,host=hostname,method=GET,result=success,server=https://url1.com,status_code=401 content_length=450i,http_response_code=401i,response_time=0.020731181,result_code=0i,result_type=“success” 1700000
status_url,host=hostname,method=GET,result=success,server=https://url2.com,status_code=500 content_length=8176i,http_response_code=500i,response_time=0.013636198,result_code=0i,result_type=“success” 1707750000 2024-02-12T15:30:21Z
E! [inputs.http_response] Error in plugin: only http and https are supported
status_url,host=hostname,method=GET,result=success,server=https://url3.com,status_code=500 content_length=7758i,http_response_code=500i,response_time=0.014732737,result_code=0i,result_type=“success” 170770000
status_url,host=hostname,method=GET,result=success,server=https://url4.com,status_code=500 content_length=6579i,http_response_code=500i,response_time=0.046924287,result_code=0i,result_type=“success” 1707000
status_url,host=hostname,method=GET,result=success,server=https://url5.com,status_code=401 content_length=450i,http_response_code=401i,response_time=0.005292509,result_code=0i,result_type=“success” 170700
status_url,host=hostname,method=GET,result=success,server=https://url6.com,status_code=401 content_length=450i,http_response_code=401i,response_time=0.066148339,result_code=0i,result_type=“success” 17077 2024-02-12T15:30:22Z
E! [telegraf] Error running agent: input plugins recorded 1 errors
can anyone please help on this
