poesel
September 29, 2023, 12:21pm
1
this looks quite simple, but I couldn’t find the right plugin.
I have this line:
Converter,host=23d86d9833d1,type=TF,zone=01 Frequency=401i,Quality="OK (0x0)" 1695986031000000000
and I want to convert it to:
Converter,host=23d86d9833d1,type=TF,zone=01 measurement="Frequency",value=401i,Quality="OK (0x0)" 1695986031000000000
So that I get two columns in my database instead of one.
How do I do that? Thanks!
jpowers
September 29, 2023, 1:29pm
2
This is what the unpivot processor does:
[[processors.unpivot]]
tag_key = "measurement"
value_key = "value"
Transforms
to
Converter,host=23d86d9833d1,measurement=Frequency,type=TF,zone=01 value=401i 1695986031000000000
Converter,host=23d86d9833d1,measurement=Quality,type=TF,zone=01 value="OK (0x0)" 1695986031000000000
Of course, that did that to both fields, Frequency and Quality. Also note the measurement value, because it is a string, becomes a tag. You can covert it back to a field if you need it to be a field instead.
If you know the names of the fields you want to do this with, you could also do it with the starlark processor.
poesel
September 29, 2023, 5:32pm
3
Thanks for the answer, but that is not what I need.
First, we can ignore the quality value. This comes from an OPC UA input and could be filtered out.
The target output is TimescaleDB (via Postgres)
This line:
would give me a tag ‘measurement’, but what I need is a field ‘measurement’ (both with the value ‘Frequency’).
The additional tag is a problem because the Timescale output creates a unique tag_id from it. But I have other values (like ‘Current’) that need to have the same ID. So I can’t have that additional tag.
jpowers
September 29, 2023, 7:07pm
4
As I mentioned above, you can then convert it back.
poesel
September 29, 2023, 7:34pm
5
jpowers:
Oh, I see. After ‘unpivot’ I run a ‘converter’ processor to convert the ‘measurement’ tag to a field of the same name. Ok, thanks.
Sorry, one last question: is it more efficient to run two processors like this or one starlark script that does the same?
Thanks!
jpowers
September 29, 2023, 8:04pm
6
Exactly! I would also mention setting the “order” value in your config to ensure it runs afterwards, something like:
order = 1
value_key = "value"
[[processors.converter]]
order = 2
I would generally say using these processors is preferred over running starlark. Starlark has a bit of overhead.
