Hello @Anaisdg,
Thank you for your response.
I have changed the measurement from Processor to Process.
Telegraf.conf:
Processes_Core_Count was added as a tag in telegraf config later converted to a field.
I could query it using Kapacitor tickscript see Output_1:
Output_1
Output_2
See column: Process_1.CPU_TIME is blank when queried in Chronograf
Output_2.2
when queried with * it works
Output_3
Queried in Grafana, same issue
Output_4
see how it was once a tag and not since converted to a field showed up under fields
Line Protocol before using Processors.converter plugin:
> Process_1,Processes_Core_Count=8,host=A700459-W10,instance=LMS,objectname=Process Handle_Count=421,Percent_Processor_Time=0,Private_Bytes=6303744,Thread_Count=6,Virtual_Bytes=79503360,Working_Set=13185024 1578571319000000000
> Process_1,Processes_Core_Count=8,host=A700459-W10,instance=PelElvDm,objectname=Process Handle_Count=131,Percent_Processor_Time=0,Private_Bytes=1695744,Thread_Count=1,Virtual_Bytes=4402032640,Working_Set=6586368 1578571319000000000
> Process_1,Processes_Core_Count=8,host=A700459-W10,instance=RuntimeBroker,objectname=Process Handle_Count=466,Percent_Processor_Time=0,Private_Bytes=7933952,Thread_Count=7,Virtual_Bytes=2203528724480,Working_Set=31768576 1578571319000000000
> Process_1,Processes_Core_Count=8,host=A700459-W10,instance=notepad++,objectname=Process Handle_Count=286,Percent_Processor_Time=0,Private_Bytes=70451200,Thread_Count=4,Virtual_Bytes=4588154880,Working_Set=38051840 1578571319000000000
Ashish
