Hi
I’m ingesting a series of not-so-nice data with telegraf, the use case is not the best one for the tool but that’s it.
Every gathered row has 2 mandatory (and known) columns, the rest of the data “may vary”, some of those high variable data will arrive serialized as tags.
What I need to do is to keep only 2 columns as tags, and convert all the others to string fields.
I came up with the following config, but I was wondering if there is a better solution to achieve a conver all except
- Turn all tags into string fields
- Turn the “known keys” back from field to tag
[[processors.converter]]
order = 1
namepass = ['MyWeirdMeasurement']
[processors.converter.tags]
string = ["*"]
order = 2
[processors.converter.fields]
tag = ['MandatoryCol1','MandatoryCol2']
Do you guys have different ideas about how to achieve this?
