I’m receiving this field domRegisterData-lane1OpticalRxPower and need to parse lane1 out of it. Then I need to take lane1 and split that into lane and 1. I then need to store lane as a tag and 1 as the value.
Is this possible to do using [[processors.regex]] ?
So far I’ve been able to get lane-1 to write as a field inside my InfluxDB like this:
order = 2
namepass = ["na_optics"]
[[processors.regex.field_rename]]
pattern = "(domRegisterData)-(\\S+)(\\d+)(\\S+)"
replacement = "${2}-${3}"
result_key = "keep"
How can I store lane as a tag instead of a field and '1` as its value?
