Trailing zeros are added to timestamp
Hi there,
I got some strange issue with xml parsing in telegraf 1.23.4.
I have an XML File with a timestamp in it like this
timestamp=“1661517236”
to parse this field I set in my telegraf config:
timestamp = “//@timestamp”
timestamp_format = “unix”
My usual output is outputs.prometheus and strangly in the output I get the timestamp added with trailing “000”
xxx_SVC_wq{cluster=“svc”,host=“hostname”,id=“svc-01-1”} 15404 1661517236000
During the Import Prometheus denies the Import because the date is (for sure) out of bounds.
So I tried outputs.file so see if this makes any difference - and it does - even more zeroes are added:
xxx_SVC,cluster=svc-01,host=hostname,id=svc-01-1 ro=41912,rb=192810950,wb=162441616,re=12,we=11126,rq=551,wq=15404,wo=43603 1661517236000000000
Next up I added three leading 0 to my XML file like this because I thought it might be some issue with the number of digits.
timestamp=“0001661518740”
nonetheless in outputs.prometheus the leading 0 are being ommited and once again I get three trailing 0 like this:
1661518740000
Does anyone have a hint for me how I can make telegraf stop adding those “0” ?
Bye, Dirk
Can you share your full config and maybe a sample XML?
1661517236000000000
When using the file output timestamps are printed with nanosecond precision, so that is why this has the additional zeros.
Thanks!
