Hello
I am trying to import data from a CSV but I cant seem to get the time stamp correct.I have tried Unix,unix_ms,unix_us and unix ns.
this is my config file
OUTPUT PLUGINS
[[inputs.file]]
files = [“log.csv”]
Data format to consume.
data_format = “csv”
##csv_column_names = [“timestamp”]
##csv_column_types = [“string”, “float”]
##csv_timestamp_column = 2
##csv_timestamp_format = “unix”
csv_timestamp_column = “session”
csv_timestamp_format = “unix_ms”
##unix, unix_ms, unix_us, unix_ns
Indicates how many rows to treat as a header. By default, the parser assumes
there is no header and will parse the first row as data. If set to anything more
than 1, column names will be concatenated with the name listed in the next header row.
If csv_column_names is specified, the column names in header will be overridden.
csv_header_row_count = 1
this is my terminal output file from sudo telegraf --config telegraf.conf --test
file,host=dennis-VirtualBox GPS\ Bearing=11.3,GPS\ Latitude=49.83719988260418,GPS\ Longitude=-119.65546879917383,GPS\ Speed=0.612,k146=-40,k15b=21.568628,k221564=26,k221942=0,k222411=49.80392,k222414=0,k222416=20,k222885=0.45,k2241a3=-8.566667,k2241b4=0,k2241b6=0,k22434f=14,k224356=0,k22436b=341.5,k22436c=21.45,k2243af=-0.39215687,k22801e=6.5,k22801f=-40.5,k228334=17.647058,ke3ee8c=0,ked22ae=7.3251753,kef253b=7.6616,session=1572740388982i,time=1572745282306i 1572740389000000000
file,host=dennis-VirtualBox GPS\ Bearing=11.3,GPS\ Latitude=49.83719594310969,GPS\ Longitude=-119.65547106228769,GPS\ Speed=1.6199999,k146=-40,k15b=21.568628,k221564=26,k221942=0,k222411=49.80392,k222414=0,k222416=20,k222885=0.45,k2241a3=-8.566667,k2241b4=0,k2241b6=0,k22434f=14,k224356=0,k22436b=341.5,k22436c=21.45,k2243af=-0.39215687,k22801e=6.5,k22801f=-40.5,k228334=17.647058,ke3ee8c=0,ked22ae=7.3251753,kef253b=7.6616,session=1572740388982i,time=1572745283307i 1572740389000000000
My data is entered in Influx it just all on the current time.
Any help would be greatly appretiated.
Dennis Mitchell
