TLS handshake error from 172.19.3.4:51466: EOF
I am unable to scape metrics from an https connection even though the cert is signed and shows as valid when accessing from a browser.
error log:
msg=“http: TLS handshake error from 172.19.3.4:51466: EOF” log_id=0VCQY49l000 service=http
http: TLS handshake error from 172.19.3.35:21999: remote error: tls: bad certificate" log_id=0VCQY49l000 service=http
Unable to gather" log_id=0VCQY49l000 error=“Get “https://xxxx:8086/metrics”: x509: certificate signed by unknown authority”
@Matthew_Brumpton as a work-around, you can register your scraper via a direct API call and set the “skip verify” flag. See this comment: How to Configure Scraper to Skip Validation on Self-signed Certificates - #2 by dan-moran
Just clarify, it is the influx metrics scaper that is not working over an https connection
Hi Matthew, have you been able to get rid of the issue? It seems I’m facing the same behavior.
No, still unresolved, just to clarify I am getting this error when trying to add influx as a grafana datasource
