Dear members!
We have made some tests on InfluxDB and we run in problems, when inserting data while 3 continous queries are active.
These exceptions are not dropped and everything goes well, when we do the same data input so that there are not continuous queries in the database.
We would like to ask for your help.
InfluxDB runs on this virtual machine:
CentOS release 6.8 (Final)
Kernel 2.6.32-642.11.1.e16.centos.plus.x86_64 on an x86_64
Memory: 2GB
Processors: 2 core ( Intel® Core™ i5-8250U CPU @ 1.60GHz 1.80 GHz )
Hard disk: SSD 45 GB
InfluxDB on virtual machine:
InfluxDB v1.7.4
Config: Default
UI management for InfluxDB: InfluxDB Studio
100.000 Measurement with Retention policy 1RP_1h
5 fields / Measurement
Batch active: (5000, 200, TimeUnit. MILLISECONDS )
Retention policies in the DB:
name,duration,shardGroupDuration,replicaN,default
autogen,0s,168h0m0s,1,True
1RP_1h,1h0m0s,1h0m0s,1,False
2RP_1H15M,1h15m0s,1h0m0s,1,False
3RP_1H30M,1h30m0s,1h0m0s,1,False
4RP_1H45M,1h45m0s,1h0m0s,1,False
Continuous queries in the DB:
CREATE CONTINUOUS QUERY CQ1perc_RP2 ON ATALLASTESZT_REAL
BEGIN
SELECT mean() INTO “2RP_1H15M”.:MEASUREMENT FROM “1RP_1h”././ GROUP BY time(1m)
END
CREATE CONTINUOUS QUERY CQ2perc_RP3 ON ATALLASTESZT_REAL
BEGIN
SELECT mean() INTO “3RP_1H30M”.:MEASUREMENT FROM “1RP_1h”././ GROUP BY time(2m)
END
CREATE CONTINUOUS QUERY CQ4perc_RP4 ON ATALLASTESZT_REAL
BEGIN
SELECT mean() INTO “4RP_1H45M”.:MEASUREMENT FROM “1RP_1h”././ GROUP BY time(4m)
END
Continuous data input (as fast as possible, around 30000 data points /sec) with real time timestamps to InfluxDB using Java Api 2.15.
We insert a data point for each of the 100000 measurements and repeat it several times.
Values are random integers in all of the 5 fields.
After 12 minutes from the start of the data input, exceptions appeared on Java console and arised periodically:
febr. 27, 2019 1:00:19 DU org.influxdb.impl.BatchProcessor write
SEVERE: Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.SocketTimeoutException: Read timed out
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:812)
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:463)
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22)
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340)
at org.influxdb.impl.BatchProcessor$2.run(BatchProcessor.java:370)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(Unknown Source)
at java.net.SocketInputStream.read(Unknown Source)
at okio.Okio$2.read(Okio.java:140)
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237)
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:358)
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:230)
at okhttp3.internal.http1.Http1Codec.readHeaderLine(Http1Codec.java:226)
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:202)
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:101)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147)
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:45)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121)
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:125)
at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22)
at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42)
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152)
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:264)
at okhttp3.RealCall.execute(RealCall.java:93)
at retrofit2.OkHttpCall.execute(OkHttpCall.java:186)
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:800)
… 11 more
s
febr. 27, 2019 1:00:52 DU org.influxdb.impl.BatchProcessor write
org.influxdb.InfluxDBIOException: java.net.SocketTimeoutException: timeout
Caused by: java.net.SocketTimeoutException: timeout
at okio.Okio$4.newTimeoutException(Okio.java:232)
at okio.AsyncTimeout.exit(AsyncTimeout.java:286)
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241)
… 11 more
… 41 more
After appearing of exceptions, I stopped the java process that was inserting records.
Some minutes after stoping the program influxdb stopped.
~# /etc/init.d/influxdb status
influxdb process is not running [ FAILED ]
The Continuous queries did not work. There was not any record in 2RP_1H15M measurements.
