Timeout error code 500
I have 48 telegraf and 1 influxdb
  • 1 telegraf insert to influxdb 3000/s
Spec server :
Ram 64 giga
Disk hdd 200 giga
Cpu 8 core
If i query "select count(msisdn) as “test” from mytsel.onehour./.*/ Groupby time (1m)
Influxdb error code 500 timeout
Please give me solution
Thnks
Hi Alvianno ,
how many measurements do you have in the database mytsel with retention policy onehour ?
Six measurement in db mytsel
do you have the same error if you do six queries , on 1 measurement at a time ?
If i query 1 measurement is good no problem
Is that ok as a workaround for you ?
it’s very problematic because influxdb timeout
