I’m trying to build a quite simple script, however it doesn’t seems to be running, I’m receiving the following error in the watch logs for the task:
lvl=error msg=“failed to realize reduce context from fields” service=kapacitor task_master=main task=testing node=influxdb_out8 err=“field “free_storage_space_minimum” missing from point”
The script looks like that:
dbrp "telegraf"."autogen"
var db = 'telegraf'
var rp = 'autogen'
var measurement = 'cloudwatch_aws_es'
var groupBy = []
var whereFilter = lambda: ("domain_name" == 'backend01-dev')
var period = 1m
var every = 30s
var name = 'testing'
var idVar = name
var message = 'DEV {{.Level}}: {{.ID}} {{ index .Fields "value" }}'
var idTag = 'alertID'
var levelTag = 'level'
var messageField = 'message'
var outputDB = 'chronograf'
var outputRP = 'autogen'
var outputMeasurement = 'alerts'
var triggerType = 'threshold'
var details = 'Please take action ASAP'
var crit = 10.0
var warn = 20.0
// var info = 30.0
var info = 50.0
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|window()
.period(period)
.every(every)
.align()
|min('free_storage_space_minimum')
.as('free_value')
|min('total_volume_size')
.as('disk_value')
// var percentage = eval(lambda: float("free_value")/float("disk_value") * 100.0)
var trigger = data
|eval(lambda: "free_value"/"disk_value" * 100)
.as('percentage')
|alert()
.info(lambda: float('percentage') < info)
.warn(lambda: float('percentage') < warn)
.crit(lambda: float('percentage') < crit)
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.details(details)
.stateChangesOnly()
.opsGenie2()
trigger
|eval(lambda: float('percentage'))
.as('value')
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag('alertName', name)
trigger
|httpOut('output')
Can anyone help me to understand where the problem is? It seems like it missing starting point, however there is a period and every defined.
Also, is there a way to actually output your “values” to the watch script? It will be very helpful in future debugging.
