I started working with InfluxDB and in the progress of joining 2 nodes
Problem
The following code is what I have tried to join 2 nodes.
The expected outcome is to have temperatures:
| Time | APC1 | APC2 |
| 18th May 2019 12:00 | 30 | 15 |
However, when I tried out the following code, I got this:
| 18th May 2019 12:00 | - | 15 |
| 18th May 2019 12:00 | 30 | - |
Here is the code
//Get temperature for UPS APC1
var current_temp1 = batch |query('select mean(value) from icinga2.autogen.apc where (metric = \'PowerNet-MIB::upsAdvBatteryTemperature.0\' and fqdn=\'apc1\')') .every(5s) .period(10m) .groupBy(*)
//Get temperature for UPS APC2
var current_temp2 = batch |query('select mean(value) from icinga2.autogen.apc where (metric = \'PowerNet-MIB::upsAdvBatteryTemperature.0\' and fqdn=\'apc2\')') .every(5s) .period(10m) .groupBy(*)
//Joining the 2 vars(current_temp1 and current_temp2)**
current_temp1
|join(current_temp2)
.as(‘apc1’, ‘apc2’)
.tolerance(5m)
.fill(1.0)
|alert()
.crit(lambda: TRUE)
.log(‘/tmp/total_temp.log’)
Any advice on how to achieve the expected result?
Thanks!
