TICK script without dbrp declaration
Hello.
I have a several agents which sends data to kapacitor with different databases and retention policies. It’s not known in advance which agent will write data to which databases, so I haven’t fixed set of dbrp-s.
I want to write task which will process all data what are coming to kapacitor and send it to remote InfluxDB.
If I write something like this
stream
    |from()
        .database('')
        .retentionPolicy('')
        .measurement('')
kapacitor throws error that dbrp should be specified.
Is it possible to use TICK scripts without dbrp declaration or specify some wildcard to solve this issue?
Thank you.
hi @mrVladOS , welcome to the community !
you can use the -dbrp option when defining a task
a dbrp is always required in a tick script I haven’t seen examples with wildcards …
hope this helps
Hi, @MarcV!
I guess it can’t solve problem
I want to define just one task which will process data from all available databases and retention policies. Is it possible?
I don’t know if you can solve it using task templates
