Thanks for your patience @nathaniel, it’s not yet solved, but we are getting closer
The field key is not forecasted.
The first three entries from the streaming replay file are:
mydb
autogen
table_test key="1",value=-0.021337869145268 0
mydb
autogen
table_test key="2",value=0.00881807571161336 10000000000
mydb
autogen
table_test key="3",value=0.0758696736565443 20000000000
I have created separate log files for debugging. The script now looks like:
var data = stream
|from()
.measurement('table_test')
|alert()
.log('/var/lib/kapacitor/alerts/raw.log')
.crit(lambda: "value" > 0.8)
|window()
.period(1d)
.every(10m)
.align()
var hw = data
|holtWinters('value', 1, 0, 10m)
.as('pred')
|alert()
.log('/var/lib/kapacitor/alerts/hwexport.log')
.crit(lambda: "pred" > 0.8)
data
|join(hw)
.as('data', 'hw')
// Inner join does not work, I have to use .fill, otherwise, no log file will be created.
.fill('null')
|alert()
.message('{{index .Fields "data.key"}} {{ index .Fields "data.value"}}')
.crit(lambda: "hw.pred" > 0.8)
.log('/var/lib/kapacitor/alerts/join.log')
.stateChangesOnly()
The first three lines of the “raw.log”, everything seems to be fine:
{"id":"table_test:nil","message":"table_test:nil is CRITICAL","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;key\u0026#34;:\u0026#34;45\u0026#34;,\u0026#34;value\u0026#34;:0.806465263666515},\u0026#34;Level\u0026#34;:\u0026#34;CRITICAL\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:31:17.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;table_test:nil is CRITICAL\u0026#34;}\n","time":"2017-04-05T15:31:17.146203883Z","duration":0,"level":"CRITICAL","data":{"Series":[{"name":"table_test","columns":["time","key","value"],"values":[["2017-04-05T15:31:17.146203883Z","45",0.806465263666515]]}],"Messages":null,"Err":null}}
{"id":"table_test:nil","message":"table_test:nil is OK","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;key\u0026#34;:\u0026#34;46\u0026#34;,\u0026#34;value\u0026#34;:0.788332170379725},\u0026#34;Level\u0026#34;:\u0026#34;OK\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:31:27.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;table_test:nil is OK\u0026#34;}\n","time":"2017-04-05T15:31:27.146203883Z","duration":10000000000,"level":"OK","data":{"Series":[{"name":"table_test","columns":["time","key","value"],"values":[["2017-04-05T15:31:27.146203883Z","46",0.788332170379725]]}],"Messages":null,"Err":null}}
{"id":"table_test:nil","message":"table_test:nil is CRITICAL","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;key\u0026#34;:\u0026#34;47\u0026#34;,\u0026#34;value\u0026#34;:0.847472078582032},\u0026#34;Level\u0026#34;:\u0026#34;CRITICAL\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:31:37.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;table_test:nil is CRITICAL\u0026#34;}\n","time":"2017-04-05T15:31:37.146203883Z","duration":0,"level":"CRITICAL","data":{"Series":[{"name":"table_test","columns":["time","key","value"],"values":[["2017-04-05T15:31:37.146203883Z","47",0.847472078582032]]}],"Messages":null,"Err":null}}
The first three lines of the “hwexport.log”, I can’t find any issues here:
{"id":"table_test:nil","message":"table_test:nil is CRITICAL","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;pred\u0026#34;:1.0480758394807048},\u0026#34;Level\u0026#34;:\u0026#34;CRITICAL\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:49:57.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;table_test:nil is CRITICAL\u0026#34;}\n","time":"2017-04-05T15:49:57.146203883Z","duration":0,"level":"CRITICAL","data":{"Series":[{"name":"table_test","columns":["time","pred"],"values":[["2017-04-05T15:49:57.146203883Z",1.0480758394807048]]}],"Messages":null,"Err":null}}
{"id":"table_test:nil","message":"table_test:nil is CRITICAL","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;pred\u0026#34;:1.0480758394807048},\u0026#34;Level\u0026#34;:\u0026#34;CRITICAL\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:53:17.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;table_test:nil is CRITICAL\u0026#34;}\n","time":"2017-04-05T15:53:17.146203883Z","duration":200000000000,"level":"CRITICAL","data":{"Series":[{"name":"table_test","columns":["time","pred"],"values":[["2017-04-05T15:53:17.146203883Z",1.0480758394807048]]}],"Messages":null,"Err":null}}
{"id":"table_test:nil","message":"table_test:nil is CRITICAL","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;pred\u0026#34;:0.8084033385401356},\u0026#34;Level\u0026#34;:\u0026#34;CRITICAL\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T16:09:57.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;table_test:nil is CRITICAL\u0026#34;}\n","time":"2017-04-05T16:09:57.146203883Z","duration":1200000000000,"level":"CRITICAL","data":{"Series":[{"name":"table_test","columns":["time","pred"],"values":[["2017-04-05T16:09:57.146203883Z",0.8084033385401356]]}],"Messages":null,"Err":null}}
The messages in the “join.log” file do have a different pattern (every second message has the same pattern). It seems like there are two newly created tables, based on the join function. One with “hw.pred” (ok) and “data.pred” (not available)
and the other with “data.key” (ok), “data.value” (ok), “hw.key” (not available), “hw.value” (not available). So I think joining both tables failes, because creating the predicted values from the holt-winters function will have a new timestamp which does not fit the timestamp of the original values anymore (even with using .tolerance(“1s”)).
{"id":"table_test:nil","message":"\u003cno value\u003e \u003cno value\u003e","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;data.pred\u0026#34;:null,\u0026#34;hw.pred\u0026#34;:1.0480758394807048},\u0026#34;Level\u0026#34;:\u0026#34;CRITICAL\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:49:57.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;\\u003cno value\\u003e \\u003cno value\\u003e\u0026#34;}\n","time":"2017-04-05T15:49:57.146203883Z","duration":0,"level":"CRITICAL","data":{"Series":[{"name":"table_test","columns":["time","data.pred","hw.pred"],"values":[["2017-04-05T15:49:57.146203883Z",null,1.0480758394807048]]}],"Messages":null,"Err":null}}
{"id":"table_test:nil","message":"45 0.806465263666515","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;data.key\u0026#34;:\u0026#34;45\u0026#34;,\u0026#34;data.value\u0026#34;:0.806465263666515,\u0026#34;hw.key\u0026#34;:null,\u0026#34;hw.value\u0026#34;:null},\u0026#34;Level\u0026#34;:\u0026#34;OK\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:50:00Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;45 0.806465263666515\u0026#34;}\n","time":"2017-04-05T15:50:00Z","duration":2853796117,"level":"OK","data":{"Series":[{"name":"table_test","columns":["time","data.key","data.value","hw.key","hw.value"],"values":[["2017-04-05T15:31:17.146203883Z","45",0.806465263666515,null,null],["2017-04-05T15:31:27.146203883Z","46",0.788332170379725,null,null],["2017-04-05T15:31:37.146203883Z","47",0.847472078582032,null,null],["2017-04-05T15:31:47.146203883Z","48",0.849678013109906,null,null],["2017-04-05T15:31:57.146203883Z","49",0.823709590787247,null,null],["2017-04-05T15:32:07.146203883Z","50",0.831483656114628,null,null],["2017-04-05T15:32:17.146203883Z","51",0.853020620915506,null,null],["2017-04-05T15:32:27.146203883Z","52",0.86259403048251,null,null],["2017-04-05T15:32:37.146203883Z","53",0.936145876802039,null,null],["2017-04-05T15:32:47.146203883Z","54",0.976367890436606,null,null],["2017-04-05T15:32:57.146203883Z","55",0.88937851514957,null,null],["2017-04-05T15:33:07.146203883Z","56",0.977133738890302,null,null],["2017-04-05T15:33:17.146203883Z","57",0.952061050395097,null,null],["2017-04-05T15:33:27.146203883Z","58",0.84955330282307,null,null],["2017-04-05T15:33:37.146203883Z","59",0.968224668406904,null,null],["2017-04-05T15:33:47.146203883Z","60",0.926929870727936,null,null],["2017-04-05T15:33:57.146203883Z","61",0.925827904875194,null,null],["2017-04-05T15:34:07.146203883Z","62",0.938144057185285,null,null],["2017-04-05T15:34:17.146203883Z","63",0.919315520026566,null,null],["2017-04-05T15:34:27.146203883Z","64",0.993264751819099,null,null],["2017-04-05T15:34:37.146203883Z","65",0.953270530442325,null,null],["2017-04-05T15:34:47.146203883Z","66",0.942575471516145,null,null],["2017-04-05T15:34:57.146203883Z","67",0.929756941895965,null,null],["2017-04-05T15:35:07.146203883Z","68",0.975892393115783,null,null],["2017-04-05T15:35:17.146203883Z","69",0.988591960153019,null,null],["2017-04-05T15:35:27.146203883Z","70",0.990990784038134,null,null],["2017-04-05T15:35:37.146203883Z","71",1.02190297565667,null,null],["2017-04-05T15:35:47.146203883Z","72",0.923219959159387,null,null],["2017-04-05T15:35:57.146203883Z","73",0.962900884395427,null,null],["2017-04-05T15:36:07.146203883Z","74",1.03207338826904,null,null],["2017-04-05T15:36:17.146203883Z","75",1.04222719419029,null,null],["2017-04-05T15:36:27.146203883Z","76",0.969899591328141,null,null],["2017-04-05T15:36:37.146203883Z","77",1.00884108655829,null,null],["2017-04-05T15:36:47.146203883Z","78",1.02114604217275,null,null],["2017-04-05T15:36:57.146203883Z","79",1.009287549929,null,null],["2017-04-05T15:37:07.146203883Z","80",0.953589237200079,null,null],["2017-04-05T15:37:17.146203883Z","81",0.877072790193951,null,null],["2017-04-05T15:37:27.146203883Z","82",1.027013269462,null,null],["2017-04-05T15:37:37.146203883Z","83",0.999182678580017,null,null],["2017-04-05T15:37:47.146203883Z","84",1.08939975106345,null,null],["2017-04-05T15:37:57.146203883Z","85",0.872077179472199,null,null],["2017-04-05T15:38:07.146203883Z","86",1.02092882382628,null,null],["2017-04-05T15:38:17.146203883Z","87",1.05118742969453,null,null],["2017-04-05T15:38:27.146203883Z","88",0.932134718462688,null,null],["2017-04-05T15:38:37.146203883Z","89",0.965014672781411,null,null],["2017-04-05T15:38:47.146203883Z","90",0.980338774007495,null,null],["2017-04-05T15:38:57.146203883Z","91",0.944458450389279,null,null],["2017-04-05T15:39:07.146203883Z","92",0.917138313456831,null,null],["2017-04-05T15:39:17.146203883Z","93",0.971758640827266,null,null],["2017-04-05T15:39:27.146203883Z","94",0.950486543744397,null,null],["2017-04-05T15:39:37.146203883Z","95",1.04540082808941,null,null],["2017-04-05T15:39:47.146203883Z","96",1.01173526583407,null,null],["2017-04-05T15:39:57.146203883Z","97",0.858635655149827,null,null],["2017-04-05T15:40:07.146203883Z","98",1.01708545374013,null,null],["2017-04-05T15:40:17.146203883Z","99",0.923138832749929,null,null],["2017-04-05T15:40:27.146203883Z","100",0.970270779116239,null,null],["2017-04-05T15:40:37.146203883Z","101",0.949530049109691,null,null],["2017-04-05T15:40:47.146203883Z","102",0.927943430350348,null,null],["2017-04-05T15:40:57.146203883Z","103",0.850110985256281,null,null],["2017-04-05T15:41:07.146203883Z","104",0.870063426889812,null,null],["2017-04-05T15:41:17.146203883Z","105",0.943297046359508,null,null],["2017-04-05T15:41:27.146203883Z","106",0.875380666427882,null,null],["2017-04-05T15:41:37.146203883Z","107",0.798631552795174,null,null],["2017-04-05T15:41:47.146203883Z","108",0.913025241545264,null,null],["2017-04-05T15:41:57.146203883Z","109",0.908900176552289,null,null],["2017-04-05T15:42:07.146203883Z","110",0.783656340829402,null,null],["2017-04-05T15:42:17.146203883Z","111",0.84428829427349,null,null],["2017-04-05T15:42:27.146203883Z","112",0.74827060391922,null,null],["2017-04-05T15:43:07.146203883Z","116",0.803032788171713,null,null],["2017-04-05T15:43:17.146203883Z","117",0.665459427875805,null,null]]}],"Messages":null,"Err":null}}
{"id":"table_test:nil","message":"\u003cno value\u003e \u003cno value\u003e","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;data.pred\u0026#34;:null,\u0026#34;hw.pred\u0026#34;:1.0480758394807048},\u0026#34;Level\u0026#34;:\u0026#34;CRITICAL\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T15:53:17.146203883Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;\\u003cno value\\u003e \\u003cno value\\u003e\u0026#34;}\n","time":"2017-04-05T15:53:17.146203883Z","duration":0,"level":"CRITICAL","data":{"Series":[{"name":"table_test","columns":["time","data.pred","hw.pred"],"values":[["2017-04-05T15:53:17.146203883Z",null,1.0480758394807048]]}],"Messages":null,"Err":null}}
{"id":"table_test:nil","message":"45 0.806465263666515","details":"{\u0026#34;Name\u0026#34;:\u0026#34;table_test\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;bumpInDoublePick\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{},\u0026#34;ID\u0026#34;:\u0026#34;table_test:nil\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;data.key\u0026#34;:\u0026#34;45\u0026#34;,\u0026#34;data.value\u0026#34;:0.806465263666515,\u0026#34;hw.key\u0026#34;:null,\u0026#34;hw.value\u0026#34;:null},\u0026#34;Level\u0026#34;:\u0026#34;OK\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2017-04-05T16:00:00Z\u0026#34;,\u0026#34;Message\u0026#34;:\u0026#34;45 0.806465263666515\u0026#34;}\n","time":"2017-04-05T16:00:00Z","duration":402853796117,"level":"OK","data":{"Series":[{"name":"table_test","columns":["time","data.key","data.value","hw.key","hw.value"],"values":[["2017-04-05T15:31:17.146203883Z","45",0.806465263666515,null,null],["2017-04-05T15:31:27.146203883Z","46",0.788332170379725,null,null],["2017-04-05T15:31:37.146203883Z","47",0.847472078582032,null,null],["2017-04-05T15:31:47.146203883Z","48",0.849678013109906,null,null],["2017-04-05T15:31:57.146203883Z","49",0.823709590787247,null,null],["2017-04-05T15:32:07.146203883Z","50",0.831483656114628,null,null],["2017-04-05T15:32:17.146203883Z","51",0.853020620915506,null,null],["2017-04-05T15:32:27.146203883Z","52",0.86259403048251,null,null],["2017-04-05T15:32:37.146203883Z","53",0.936145876802039,null,null],["2017-04-05T15:32:47.146203883Z","54",0.976367890436606,null,null],["2017-04-05T15:32:57.146203883Z","55",0.88937851514957,null,null],["2017-04-05T15:33:07.146203883Z","56",0.977133738890302,null,null],["2017-04-05T15:33:17.146203883Z","57",0.952061050395097,null,null],["2017-04-05T15:33:27.146203883Z","58",0.84955330282307,null,null],["2017-04-05T15:33:37.146203883Z","59",0.968224668406904,null,null],["2017-04-05T15:33:47.146203883Z","60",0.926929870727936,null,null],["2017-04-05T15:33:57.146203883Z","61",0.925827904875194,null,null],["2017-04-05T15:34:07.146203883Z","62",0.938144057185285,null,null],["2017-04-05T15:34:17.146203883Z","63",0.919315520026566,null,null],["2017-04-05T15:34:27.146203883Z","64",0.993264751819099,null,null],["2017-04-05T15:34:37.146203883Z","65",0.953270530442325,null,null],["2017-04-05T15:34:47.146203883Z","66",0.942575471516145,null,null],["2017-04-05T15:34:57.146203883Z","67",0.929756941895965,null,null],["2017-04-05T15:35:07.146203883Z","68",0.975892393115783,null,null],["2017-04-05T15:35:17.146203883Z","69",0.988591960153019,null,null],["2017-04-05T15:35:27.146203883Z","70",0.990990784038134,null,null],["2017-04-05T15:35:37.146203883Z","71",1.02190297565667,null,null],["2017-04-05T15:35:47.146203883Z","72",0.923219959159387,null,null],["2017-04-05T15:35:57.146203883Z","73",0.962900884395427,null,null],["2017-04-05T15:36:07.146203883Z","74",1.03207338826904,null,null],["2017-04-05T15:36:17.146203883Z","75",1.04222719419029,null,null],["2017-04-05T15:36:27.146203883Z","76",0.969899591328141,null,null],["2017-04-05T15:36:37.146203883Z","77",1.00884108655829,null,null],["2017-04-05T15:36:47.146203883Z","78",1.02114604217275,null,null],["2017-04-05T15:36:57.146203883Z","79",1.009287549929,null,null],["2017-04-05T15:37:07.146203883Z","80",0.953589237200079,null,null],["2017-04-05T15:37:17.146203883Z","81",0.877072790193951,null,null],["2017-04-05T15:37:27.146203883Z","82",1.027013269462,null,null],["2017-04-05T15:37:37.146203883Z","83",0.999182678580017,null,null],["2017-04-05T15:37:47.146203883Z","84",1.08939975106345,null,null],["2017-04-05T15:37:57.146203883Z","85",0.872077179472199,null,null],["2017-04-05T15:38:07.146203883Z","86",1.02092882382628,null,null],["2017-04-05T15:38:17.146203883Z","87",1.05118742969453,null,null],["2017-04-05T15:38:27.146203883Z","88",0.932134718462688,null,null],["2017-04-05T15:38:37.146203883Z","89",0.965014672781411,null,null],["2017-04-05T15:38:47.146203883Z","90",0.980338774007495,null,null],["2017-04-05T15:38:57.146203883Z","91",0.944458450389279,null,null],["2017-04-05T15:39:07.146203883Z","92",0.917138313456831,null,null],["2017-04-05T15:39:17.146203883Z","93",0.971758640827266,null,null],["2017-04-05T15:39:27.146203883Z","94",0.950486543744397,null,null],["2017-04-05T15:39:37.146203883Z","95",1.04540082808941,null,null],["2017-04-05T15:39:47.146203883Z","96",1.01173526583407,null,null],["2017-04-05T15:39:57.146203883Z","97",0.858635655149827,null,null],["2017-04-05T15:40:07.146203883Z","98",1.01708545374013,null,null],["2017-04-05T15:40:17.146203883Z","99",0.923138832749929,null,null],["2017-04-05T15:40:27.146203883Z","100",0.970270779116239,null,null],["2017-04-05T15:40:37.146203883Z","101",0.949530049109691,null,null],["2017-04-05T15:40:47.146203883Z","102",0.927943430350348,null,null],["2017-04-05T15:40:57.146203883Z","103",0.850110985256281,null,null],["2017-04-05T15:41:07.146203883Z","104",0.870063426889812,null,null],["2017-04-05T15:41:17.146203883Z","105",0.943297046359508,null,null],["2017-04-05T15:41:27.146203883Z","106",0.875380666427882,null,null],["2017-04-05T15:41:37.146203883Z","107",0.798631552795174,null,null],["2017-04-05T15:41:47.146203883Z","108",0.913025241545264,null,null],["2017-04-05T15:41:57.146203883Z","109",0.908900176552289,null,null],["2017-04-05T15:42:07.146203883Z","110",0.783656340829402,null,null],["2017-04-05T15:42:17.146203883Z","111",0.84428829427349,null,null],["2017-04-05T15:42:27.146203883Z","112",0.74827060391922,null,null],["2017-04-05T15:43:07.146203883Z","116",0.803032788171713,null,null],["2017-04-05T15:43:17.146203883Z","117",0.665459427875805,null,null],["2017-04-05T15:57:07.146203883Z","200",0.821036674196026,null,null],["2017-04-05T15:57:17.146203883Z","201",0.73029505215544,null,null],["2017-04-05T15:58:07.146203883Z","206",0.901157862751018,null,null],["2017-04-05T15:58:17.146203883Z","207",0.867616432372154,null,null],["2017-04-05T15:58:27.146203883Z","208",0.858176951735647,null,null],["2017-04-05T15:58:37.146203883Z","209",0.851089086493786,null,null],["2017-04-05T15:58:47.146203883Z","210",0.943305888631815,null,null],["2017-04-05T15:58:57.146203883Z","211",0.845032948380737,null,null],["2017-04-05T15:59:07.146203883Z","212",0.890394633578303,null,null],["2017-04-05T15:59:17.146203883Z","213",0.886702736749359,null,null],["2017-04-05T15:59:27.146203883Z","214",0.80120704185473,null,null],["2017-04-05T15:59:37.146203883Z","215",0.901836120063745,null,null],["2017-04-05T15:59:47.146203883Z","216",0.9457774288083,null,null],["2017-04-05T15:59:57.146203883Z","217",0.933623554689181,null,null]]}],"Messages":null,"Err":null}}
Kapacitor also writes this many times into the console:
kapacitor_1 | [bumpInDoublePick:alert8] 2017/04/05 15:24:07 E! error evaluating expression for level CRITICAL: no field or tag exists for hw.pred
Thanks again and best regards,
Simon
