Hi all,
We are using InfluxDB and Grafana (with installed Discrete plugin) to draw different java’s threads states. Something like functionality provided by VisualVM for thread monitoring. However, I have the problem described here. Obviously fill(previous) would be the best solution but as I see this is not implemented yet. Right now Grafana is querying InfluxDB for specific interval, let’s say from (now - 1m) up to now. If I am recording java thread states on every 30 seconds, I will get info only for the last point which I have saved into this interval. If however, the point is saved in (now() -1m and 1 second) I will report the point around (now() - 30s) and for Grafana would be impossible to tell what was the last state (reported in now() -1m and 1 second). I could not think of a way to overcome this limitation. Any help is much appreciated.
