Hello All,
i would highly appreciate your help, as (again) i have come to a stop end for my project:
I am using telegraf input plugin openweathermap which writes the data into my influxdb database “telegraf_db”. Now i want to visualize the data using grafana. Unfortunately i am not able to make the correct select statement to get seperate values. The issue is, that for one timestamp multiple entries (from former telegraf entries) exist. What i need, is a query which takes only the one and last value for each tag value (120h, 117h, 114h, 111h, …)
SELECT * FROM weather WHERE city = 'Waiblingen' ORDER BY time DESC LIMIT 20
time city city_id cloudiness country forecast host humidity pressure rain sunrise sunset temperature visibility wind_degrees wind_speed
2019-11-26T18:00:00Z Waiblingen 2815330 100 DE 120h openhabpi 89 1008 0.31 9.01 172 2.61
2019-11-26T15:00:00Z Waiblingen 2815330 100 DE 117h openhabpi 89 1010 0 8.78 171 1.14
2019-11-26T15:00:00Z Waiblingen 2815330 93 DE 120h openhabpi 78 1015 0 7.75 264 1.58
2019-11-26T12:00:00Z Waiblingen 2815330 98 DE 114h openhabpi 80 1011 0 10.63 234 2.15
2019-11-26T12:00:00Z Waiblingen 2815330 100 DE 117h openhabpi 67 1015 0 10.32 255 4.12
2019-11-26T12:00:00Z Waiblingen 2815330 100 DE 120h openhabpi 67 1015 0 10.32 255 4.12
2019-11-26T09:00:00Z Waiblingen 2815330 100 DE 117h openhabpi 80 1015 0.13 8.39 231 3.89
2019-11-26T09:00:00Z Waiblingen 2815330 95 DE 120h openhabpi 82 1015 0 8.78 227 3.93
2019-11-26T09:00:00Z Waiblingen 2815330 100 DE 114h openhabpi 80 1015 0.13 8.39 231 3.89
2019-11-26T09:00:00Z Waiblingen 2815330 97 DE 111h openhabpi 85 1012 0 8.86 220 2.8
2019-11-26T06:00:00Z Waiblingen 2815330 100 DE 114h openhabpi 90 1014 0.13 6.91 211 2.77
2019-11-26T06:00:00Z Waiblingen 2815330 100 DE 111h openhabpi 90 1014 0.13 6.91 211 2.77
2019-11-26T06:00:00Z Waiblingen 2815330 97 DE 120h openhabpi 90 1014 0 6.65 218 3.2
2019-11-26T06:00:00Z Waiblingen 2815330 100 DE 108h openhabpi 94 1012 0 6.49 208 2.26
2019-11-26T06:00:00Z Waiblingen 2815330 97 DE 117h openhabpi 90 1014 0 6.65 218 3.2
2019-11-26T03:00:00Z Waiblingen 2815330 100 DE 108h openhabpi 90 1014 0 6.7 210 2.29
2019-11-26T03:00:00Z Waiblingen 2815330 96 DE 117h openhabpi 85 1015 0 6.8 203 3.11
2019-11-26T03:00:00Z Waiblingen 2815330 100 DE 105h openhabpi 91 1012 0.13 6.8 203 2.27
2019-11-26T03:00:00Z Waiblingen 2815330 83 DE 120h openhabpi 88 1016 0 5.05 159 1.75
2019-11-26T03:00:00Z Waiblingen 2815330 96 DE 114h openhabpi 85 1015 0 6.8 203 3.11
My expected answer is something like this
So how can i achieve this? I tried in multiple ways (for the last 9hrs now
) with DISTINCT(), GROUP BY, LIMIT, SLIMIT, LAST in many different variants but none of them was successfull. Can you pls pls help me out in this.
A similiar, but unanswered question can be found here:
https://community.influxdata.com/t/plotting-weather-forecast-data/9135
Reference to telegraf openweathermap input plugin can be found here:
https://github.com/influxdata/telegraf/tree/master/plugins/inputs/openweathermap
Documentation to openweathermap forecast can be found here:
https://openweathermap.org/forecast5#5days
Thanks very much in advance,
Patrick
