Telegraf to read azure event hub via inputs.kafka_consumer
Dear all,
I am new to influx and telegraf and we are pretty much in MS Azure PaaS services.
Since a while the Microsoft Azure EventHub provides Kafka 1.0 and later protocol support.
Data streaming with Event Hubs using the Kafka protocol
To receive events and send to InfluxDB I configured the telegraf [inputs.kafka_consumer] as follows.
[[inputs.kafka_consumer]]
#   ## kafka servers
   brokers = ["<namespace>.servicebus.windows.net:9093"]
#   ## topic(s) to consume
   topics = ["<Event Hub>"]
#   ## Add topic as tag if topic_tag is not empty
#   # topic_tag = ""
#   ## Optional Client id
    client_id = "AzEvHub"
#   ## Set the minimal supported Kafka version.  Setting this enables the use of new
#   ## Kafka features and APIs.  Of particular interest, lz4 compression
#   ## requires at least version 0.10.0.0.
#   ##   ex: version = "1.1.0"
    version = "1.1.0"
#   ## Optional TLS Config
#   # tls_ca = "/etc/telegraf/ca.pem"
#   # tls_cert = "/etc/telegraf/cert.pem"
#   # tls_key = "/etc/telegraf/key.pem"
#   ## Use TLS but skip chain & host verification
#   # insecure_skip_verify = false
#   ## Optional SASL Config
    sasl_username = "<username>"
    sasl_password = "<password>"
#   ## the name of the consumer group
   consumer_group = "telegraf"
#   ## Offset (must be either "oldest" or "newest")
   offset = "oldest"
#   ## Maximum length of a message to consume, in bytes (default 0/unlimited);
#   ## larger messages are dropped
   max_message_len = 1000000
#   ## Maximum messages to read from the broker that have not been written by an
#   ## output.  For best throughput set based on the number of metrics within
#   ## each message and the size of the output's metric_batch_size.
#   ## For example, if each message from the queue contains 10 metrics and the
#   ## output metric_batch_size is 1000, setting this to 100 will ensure that a
#   ## full batch is collected and the write is triggered immediately without
#   ## waiting until the next flush_interval.
#   # max_undelivered_messages = 1000
#   ## Data format to consume.
#   ## Each data format has its own unique set of configuration options, read
#   ## more about them here:
#   ## https://github.com/influxdata/telegraf/blob/master/docs/DATA_FORMATS_INPUT.md
   data_format = "influx"
Whatever I try in brokers with or without port I always receive an error.
Serivce for input inputs.kafka_consumer failed to start: kafka: client has run out of available brokers to talk to (Is your cluster reachable?)
Can someone help?
Thx
Bruno
Can you try with Telegraf 1.12.0-rc1, this plugin has been updated to use a newer version of the Sarama Kafka library. If you still run into problems, run Telegraf with the --debug flag for additional logging.
Thx daniel for the quick support.
We updated telegraf and restarted with the same configuration.
No success …
2019-09-02T07:52:49Z D! [sarama] client/metadata fetching metadata for all topics from broker *.servicebus.windows.net:9093
2019-09-02T07:52:49Z D! [sarama] Failed to read SASL handshake header : EOF
2019-09-02T07:52:49Z D! [sarama] Error while performing SASL handshake *.servicebus.windows.net:9093
2019-09-02T07:52:49Z D! [sarama] Closed connection to broker *.servicebus.windows.net:9093
On using kafka port 9092 I get a different log.
2019-09-02T07:38:19Z D! [sarama] client/metadata fetching metadata for all topics from broker *.servicebus.windows.net:9092
2019-09-02T07:38:49Z D! [sarama] Failed to connect to broker *.servicebus.windows.net:9092: dial tcp 13.69.64.0:9092: i/o timeout
2019-09-02T07:38:49Z D! [sarama] client/metadata got error from broker -1 while fetching metadata: dial tcp 13.69.64.0:9092: i/o timeout
With this it looks like the port 9092 works better than 9093. Looks like SASL authenication works. However the Microsoft documentation Data streaming with Event Hubs using the Kafka protocol uses port 9093.
Any ideas how to proceed?
  • Is there a way to get more log on sarama?
  • The different ports 9092 and 9093 confuses me.
Thx for help …
Bruno
a quick add on …
The config.go says in line 61ff
// Version is the SASL Protocol Version to use
// Kafka > 1.x should use V1, except on Azure EventHub which use V0
Version int16
How is this parameter set from telegraf?
thx
Bruno
The version is not selectable currently, however it looks like the default is V0 anyway. Could you open a new issue on the Telegraf Github page for the errors connecting to event hub?
Thanks for updating … I created an issue, and hoping to get that fixed soon.
