Hello Everyone,
I hope this Topic finds you well and healthy,
Im new here and confused regarding a point,
I have a telegraf [Telegraf 1.17.3 (git: HEAD 24a552b9)] agent installed in a Centos 8 VM, on the installation directory I have this files
telegraf.conf
telegraf.d
Also I have a influxdb 1.8 installed on a docker image
I have a cisco switch with SNMP configured (I test it using SNMPWALK) I want telegraf to get Data from Cisco switch using SNMP,
I found a plugin in Git called SNMP : telegraf/plugins/inputs/snmp at master · influxdata/telegraf · GitHub
My questions are,
How to install/add this plugin from githum to my Telagraf config ?
I should Write a new config file or just add some codes to the default config file ‘Telegraf.conf’ ?
and regarding the Cisco switch SNMP MIb files should be stored on the SNMPWALK directory or I should store it somewhere to make Telegraf use it ?
Thank you so much for the help
I’m available for any extra information,
