I have few sensors sending data over MQTT and for which I would like to create 3 buckets:
- one with raw data, to be kept for max 30 days
- one with aggregated data, per hour, to be kept for 90 days
- one with aggregated data, per day, to be kept for long periods
Below is the way I implemented the first two but I have the feeling could be done easier. In addition, I don’t know how to do the 3rd one.
[[aggregators.basicstats]]
alias = "basic_stat"
## The period on which to flush & clear the aggregator.
period = "1h"
## If true, the original metric will be dropped by the
## aggregator and will not get sent to the output plugins.
drop_original = false
## Configures which basic stats to push as fields
# stats = ["count","diff","rate","min","max","mean","non_negative_diff","non_negative_rate","stdev","s2","sum","interval"]
stats = ["count","min","max","mean"]
fieldpass = ["humidity" , "temperature_C" , "rssi"]
[[outputs.influxdb_v2]]
alias = "raw_data"
urls = ["http://${DOCKER_INFLUXDB_INIT_HOST}:8086"]
## Token for authentication.
token = "$DOCKER_INFLUXDB_INIT_ADMIN_TOKEN"
organization = "$DOCKER_INFLUXDB_INIT_ORG"
bucket = "$DOCKER_INFLUXDB_INIT_BUCKET_RAW"
insecure_skip_verify = false
fielddrop = ["*_count", "*_min", "*_max", "*_mean"]
# # Configuration for sending metrics to InfluxDB
alias = "aggregated_data"
bucket = "$DOCKER_INFLUXDB_INIT_BUCKET_AGG"
fieldpass = ["*_count", "*_min", "*_max", "*_mean"]
I tried to tag, as below, all aggregated data but didn’t work.
[aggregators.basicstats.tags]
influxdb_database = "aggregated"
In my view, this would solve the implementation of 3rd bucket (bucket tags for: inputs.mqtt_consumer, aggregation per hour and aggregation per day) but not working put me in the position to remain with the first 2 buckets.
Thank you
