Telegraf ping plugin issue
We are using latest version of ping plugin and we use about 1000 ip to ping once in every 5 min, but when we see the logs we see alot of logs like below.
> 2019-05-13T10:45:28Z E! [inputs.ping]: Error in plugin: host 10.20.6.127: signal: killed
2019-05-13T10:45:28Z E! [inputs.ping]: Error in plugin: host 10.20.6.13: signal: killed
2019-05-13T10:45:28Z E! [inputs.ping]: Error in plugin: host 10.20.6.14: signal: killed
2019-05-13T10:45:28Z E! [inputs.ping]: Error in plugin: host 10.20.6.15: signal: killed
2019-05-13T10:45:28Z E! [inputs.ping]: Error in plugin: host 10.20.6.83: signal: killed
2019-05-13T10:45:28Z E! [inputs.ping]: Error in plugin: host 10.20.6.10: signal: killed
2019-05-13T10:45:28Z E! [inputs.ping]: Error in plugin: host 10.20.6.11: signal: killed
2019-05-13T10:45:30Z E! [inputs.ping]: Error in plugin: host 10.1.7.46: signal: killed
It is not related to file limit as i have set it to 65000. OS is RHEL7
Hi Amit_Kumar_Singh ,
this seems related to a bug …
best regards ,
