I’m trying to make a docker compose for influxdb and telegraf.
But everytime I have the error 411 length required that popped out of nowhere.
I tried on 3 different machines :
- windows + docker OK
- wsl 2 debian + docker integration OK
- debian VM + docker not OK
The error output :
2022-12-16T11:02:48Z I! Using config file: /etc/telegraf/telegraf.conf
2022-12-16T11:02:48Z I! Starting Telegraf 1.25.0
2022-12-16T11:02:48Z I! Available plugins: 228 inputs, 9 aggregators, 26 processors, 21 parsers, 57 outputs, 2 secret-stores
2022-12-16T11:02:48Z I! Loaded inputs: cpu syslog
2022-12-16T11:02:48Z I! Loaded aggregators:
2022-12-16T11:02:48Z I! Loaded processors:
2022-12-16T11:02:48Z I! Loaded secretstores:
2022-12-16T11:02:48Z I! Loaded outputs: influxdb_v2
2022-12-16T11:02:48Z I! Tags enabled: host=54693aed0514
2022-12-16T11:02:48Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"54693aed0514", Flush Interval:10s
2022-12-16T11:03:08Z E! [outputs.influxdb_v2] Failed to write metric to adminbucket (will be dropped: 411 Length Required): 411 Length Required
Here all my setup file (I took some from the tig-stack repo)
docker compose :
services:
influxdb:
image: influxdb:latest
volumes:
- influxdb-data:/var/lib/influxdb2:rw
- ./influxdb.conf:/etc/influxdb2/config.yml
env_file:
- .env
entrypoint: [ "./entrypoint.sh" ]
restart: on-failure:10
ports:
- ${DOCKER_INFLUXDB_INIT_PORT}:8086
telegraf:
image: telegraf:latest
volumes:
- ${TELEGRAF_CFG_PATH}:/etc/telegraf/telegraf.conf:ro
env_file:
- .env
depends_on:
- influxdb
ports:
- ${TELEGRAF_INIT_PORT_TCP}:6514/tcp
volumes:
influxdb-data:
.env :
DOCKER_INFLUXDB_INIT_MODE=setup
## Environment variables used during the setup and operation of the stack
# Primary InfluxDB admin/superuser credentials
DOCKER_INFLUXDB_INIT_USERNAME=tli
DOCKER_INFLUXDB_INIT_PASSWORD=tlipassword
DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=o05VgCLc8K1QD0hVQxnpTi89ncBHF290jB1/svOriTqeprvd5DaGgC/NxUepcrUZLQ/mXpAeunwPjyF3/3rh/g==
# Primary InfluxDB organization & bucket definitions
DOCKER_INFLUXDB_INIT_ORG=srr
DOCKER_INFLUXDB_INIT_BUCKET=tlibucket
# Primary InfluxDB bucket retention period
# NOTE: Valid units are nanoseconds (ns), microseconds(us), milliseconds (ms)
# seconds (s), minutes (m), hours (h), days (d), and weeks (w).
DOCKER_INFLUXDB_INIT_RETENTION=1h
# InfluxDB port & hostname definitions
DOCKER_INFLUXDB_INIT_PORT=8087
DOCKER_INFLUXDB_INIT_HOST=influxdb
# Telegraf configuration file
# Will be mounted to container and used as telegraf configuration
TELEGRAF_CFG_PATH=./telegraf.conf
TELEGRAF_INIT_PORT_TCP=6515
entrypoint.sh :
#!/bin/bash
# Protects script from continuing with an error
set -eu -o pipefail
# Ensures environment variables are set
export DOCKER_INFLUXDB_INIT_MODE=$DOCKER_INFLUXDB_INIT_MODE
export DOCKER_INFLUXDB_INIT_USERNAME=$DOCKER_INFLUXDB_INIT_USERNAME
export DOCKER_INFLUXDB_INIT_PASSWORD=$DOCKER_INFLUXDB_INIT_PASSWORD
export DOCKER_INFLUXDB_INIT_ORG=$DOCKER_INFLUXDB_INIT_ORG
export DOCKER_INFLUXDB_INIT_BUCKET=$DOCKER_INFLUXDB_INIT_BUCKET
export DOCKER_INFLUXDB_INIT_RETENTION=$DOCKER_INFLUXDB_INIT_RETENTION
export DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=$DOCKER_INFLUXDB_INIT_ADMIN_TOKEN
export DOCKER_INFLUXDB_INIT_PORT=$DOCKER_INFLUXDB_INIT_PORT
export DOCKER_INFLUXDB_INIT_HOST=$DOCKER_INFLUXDB_INIT_HOST
telegraf.conf :
# Telegraf Configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Environment variables can be used anywhere in this config file, simply surround
# them with ${}. For strings the variable must be within quotes (ie, "${STR_VAR}"),
# for numbers and booleans they should be plain (ie, ${INT_VAR}, ${BOOL_VAR})
# Global tags can be specified here in key="value" format.
[global_tags]
# dc = "us-east-1" # will tag all metrics with dc=us-east-1
# rack = "1a"
## Environment variables can be used as tags, and throughout the config file
# user = "$USER"
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 5000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 10000
collection_jitter = "0s"
## Collection offset is used to shift the collection by the given amount.
## This can be be used to avoid many plugins querying constraint devices
## at the same time by manually scheduling them in time.
# collection_offset = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "10s"
## Collected metrics are rounded to the precision specified. Precision is
## specified as an interval with an integer + unit (e.g. 0s, 10ms, 2us, 4s).
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s:
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
precision = "0s"
## Log at debug level.
debug = true
## Log only error level messages.
# quiet = false
## Log target controls the destination for logs and can be one of "file",
## "stderr" or, on Windows, "eventlog". When set to "file", the output file
## is determined by the "logfile" setting.
# logtarget = "file"
## Name of the file to be logged to when using the "file" logtarget. If set to
## the empty string then logs are written to stderr.
# logfile = "/tmp/telegraf.log"
## The logfile will be rotated after the time interval specified. When set
## to 0 no time based rotation is performed. Logs are rotated only when
## written to, if there is no log activity rotation may be delayed.
# logfile_rotation_interval = "0h"
## The logfile will be rotated when it becomes larger than the specified
## size. When set to 0 no size based rotation is performed.
# logfile_rotation_max_size = "10MB"
## Maximum number of rotated archives to keep, any older logs are deleted.
## If set to -1, no archives are removed.
# logfile_rotation_max_archives = 5
## Pick a timezone to use when logging or type 'local' for local time.
## Example: America/Chicago
# log_with_timezone = ""
## Override default hostname, if empty use os.Hostname()
hostname = "telegraf"
omit_hostname = false
## Method of translating SNMP objects. Can be "netsnmp" (deprecated) which
## translates by calling external programs snmptranslate and snmptable,
## or "gosmi" which translates using the built-in gosmi library.
# snmp_translator = "netsnmp"
# Configuration for sending metrics to InfluxDB 2.0
[[outputs.influxdb_v2]]
## ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
urls = ["http://${DOCKER_INFLUXDB_INIT_HOST}:8086", "http://127.0.0.1:8086"]
## Token for authentication.
token = "${DOCKER_INFLUXDB_INIT_ADMIN_TOKEN}"
## Organization is the name of the organization you wish to write to.
organization = "${DOCKER_INFLUXDB_INIT_ORG}"
bucket = "${DOCKER_INFLUXDB_INIT_BUCKET}"
## The value of this tag will be used to determine the bucket. If this
## tag is not set the 'bucket' option is used as the default.
# bucket_tag = ""
## If true, the bucket tag will not be added to the metric.
# exclude_bucket_tag = false
## Timeout for HTTP messages.
# timeout = "5s"
## Additional HTTP headers
http_headers = {"Content-Length" = "0"}
## HTTP Proxy override, if unset values the standard proxy environment
## variables are consulted to determine which proxy, if any, should be used.
# http_proxy = "http://10.0.236.130:3128"
## HTTP User-Agent
# user_agent = "telegraf"
## Content-Encoding for write request body, can be set to "gzip" to
## compress body or "identity" to apply no encoding.
content_encoding = "gzip"
## Enable or disable uint support for writing uints influxdb 2.0.
# influx_uint_support = false
## Optional TLS Config for use on HTTP connections.
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
# Send telegraf metrics to file(s)
# [[outputs.file]]
# ## Files to write to, "stdout" is a specially handled file.
# files = ["/tmp/metrics.out"]
# ## Use batch serialization format instead of line based delimiting. The
# ## batch format allows for the production of non line based output formats and
# ## may more efficiently encode and write metrics.
# # use_batch_format = false
# ## The file will be rotated after the time interval specified. When set
# ## to 0 no time based rotation is performed.
# # rotation_interval = "0h"
# ## The logfile will be rotated when it becomes larger than the specified
# ## size. When set to 0 no size based rotation is performed.
# rotation_max_size = "5MB"
# ## Maximum number of rotated archives to keep, any older logs are deleted.
# ## If set to -1, no archives are removed.
# rotation_max_archives = 5
# ## Data format to output.
# ## Each data format has its own unique set of configuration options, read
# ## more about them here:
# ## https://github.com/influxdata/telegraf/blob/master/docs/DATA_FORMATS_OUTPUT.md
# data_format = "influx"
# SERVICE INPUT PLUGINS #
[[inputs.syslog]]
## Protocol, address and port to host the syslog receiver.
## If no host is specified, then localhost is used.
## If no port is specified, 6514 is used (RFC5425#section-4.1).
## ex: server = "tcp://localhost:6514"
## server = "udp://:6514"
## server = "unix:///var/run/telegraf-syslog.sock"
## When using tcp, consider using 'tcp4' or 'tcp6' to force the usage of IPv4
## or IPV6 respectively. There are cases, where when not specified, a system
## may force an IPv4 mapped IPv6 address.
server = "tcp://:6514"
## TLS Config
# tls_allowed_cacerts = ["/etc/telegraf/ca.pem"]
## Period between keep alive probes.
## 0 disables keep alive probes.
## Defaults to the OS configuration.
## Only applies to stream sockets (e.g. TCP).
# keep_alive_period = "5m"
## Maximum number of concurrent connections (default = 0).
## 0 means unlimited.
# max_connections = 1024
## Read timeout is the maximum time allowed for reading a single message (default = 5s).
# read_timeout = "5s"
## The framing technique with which it is expected that messages are transported (default = "octet-counting").
## Whether the messages come using the octect-counting (RFC5425#section-4.3.1, RFC6587#section-3.4.1),
## or the non-transparent framing technique (RFC6587#section-3.4.2).
## Must be one of "octect-counting", "non-transparent".
# framing = "octet-counting"
## The trailer to be expected in case of non-transparent framing (default = "LF").
## Must be one of "LF", or "NUL".
# trailer = "LF"
## Whether to parse in best effort mode or not (default = false).
## By default best effort parsing is off.
best_effort = true
## The RFC standard to use for message parsing
## By default RFC5424 is used. RFC3164 only supports UDP transport (no streaming support)
## Must be one of "RFC5424", or "RFC3164".
# syslog_standard = "RFC5424"
## Character to prepend to SD-PARAMs (default = "_").
## A syslog message can contain multiple parameters and multiple identifiers within structured data section.
## Eg., [id1 name1="val1" name2="val2"][id2 name1="val1" nameA="valA"]
## For each combination a field is created.
## Its name is created concatenating identifier, sdparam_separator, and parameter name.
# sdparam_separator = "_"
# Read metrics about cpu usage
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = true
## Whether to report total system cpu stats or not
totalcpu = true
## If true, collect raw CPU time metrics
collect_cpu_time = false
## If true, compute and report the sum of all non-idle CPU states
report_active = false
## If true and the info is available then add core_id and physical_id tags
core_tags = false
