Telegraf Plugin outputs.influxdb_v2: No input in the influxDB
Hi there,
Im new to influx and telegraf environment.
influx DB V2.03
Telegraf 1.17
I have probably a simple error in my setup. My influx instance don’t get any inputs from telegraf output plugin.
Here is my telegraf output config:
[agent]
  interval = "10s"
  round_interval = true
  metric_batch_size = 1000000
  metric_buffer_limit = 100000
  collection_jitter = "0s"
  flush_interval = "10s"
  flush_jitter = "0s"
  precision = ""
  debug = false
  quiet = false
  logfile = ""
  hostname = ""
  omit_hostname = false
[[inputs.http]]
  urls = ["https://feeds.citibikenyc.com/stations/stations.json"]
  name_override = "citibikenyc"
  tagexclude = ["url", "host"]
  data_format = "json"
  json_query = "stationBeanList"
  tag_keys = ["id", "stationName", "city", "postalCode"]
  fielddrop = ["landMark"]
  json_string_fields = ["statusValue", "stAddress1", "stAddress2", "location", "landMark"]
  json_time_key = "lastCommunicationTime"
  json_time_format = "2006-01-02 03:04:05 PM"
  json_timezone = "America/New_York"
[[outputs.file]]
  files = ["stdout", "/home/music/influx_testdata/metrics.out"]
[[outputs.influxdb_v2]]
  urls = ["http://localhost:8086"]
  #urls = ["udp://localhost:8089"]
  ## Token for authentication.
  token = "my_token"
  organization = "home"
  bucket = "test"
My Input section follows these get started http plugin
and also I add a file output to my local machine, to check if something wrong with the input HTTP, but this works fine.
.influxdbv2/configs
[default]
  url = "http://localhost:8086"
  token = "my_token"
  org = "home"
  active = true
My first thoughts was that is something wrong with HTTP socket, but i also tried this Influx Sample Data Guide. I can browse the data in influxdb UI.
If i start
telegraf -config /etc/telegraf/telegraf.conf
The data will be stored locally, but nothing is sent to the influxDB.
I tried many different tokens, but always the same result.
Where is my issue?
Im littlebit desperate. So please help me!
Thank you very much!!
Greetings,
Jan
Hello @dece,
Welcome!
I’m not sure.
Can you please set debug = true in the agent portion of your config?
To test that the data is being sent to InfluxDB, run the following (replacing telegraf.conf with the path to your configuration file):
telegraf -config ~/telegraf.conf -test
And share the output/line protocol please?
Thanks!
Hello and thank you!
for sure:
with -test
    telegraf -config /etc/telegraf/telegraf.conf -test
    2021-01-27T19:47:00Z I! Starting Telegraf 1.17.0
    2021-01-27T19:47:00Z D! [agent] Initializing plugins
    2021-01-27T19:47:00Z D! [agent] Starting service inputs
    > citibikenyc,id=72,stationName=W\ 52\ St\ &\ 11\ Ave availableBikes=7,availableDocks=32,latitude=40.76727216,location="",longitude=-73.99392888,stAddress1="W 52 St & 11 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498215000000000
    > citibikenyc,id=79,stationName=Franklin\ St\ &\ W\ Broadway availableBikes=33,availableDocks=0,latitude=40.71911552,location="",longitude=-74.00666661,stAddress1="Franklin St & W Broadway",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=33 1453498361000000000
    > citibikenyc,id=82,stationName=St\ James\ Pl\ &\ Pearl\ St availableBikes=0,availableDocks=27,latitude=40.71117416,location="",longitude=-74.00016545,stAddress1="St James Pl & Pearl St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498181000000000
    > citibikenyc,id=83,stationName=Atlantic\ Ave\ &\ Fort\ Greene\ Pl availableBikes=40,availableDocks=21,latitude=40.68382604,location="",longitude=-73.97632328,stAddress1="Atlantic Ave & Fort Greene Pl",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=62 1453498353000000000
    > citibikenyc,id=116,stationName=W\ 17\ St\ &\ 8\ Ave availableBikes=19,availableDocks=19,latitude=40.74177603,location="",longitude=-74.00149746,stAddress1="W 17 St & 8 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498352000000000
    > citibikenyc,id=119,stationName=Park\ Ave\ &\ St\ Edwards\ St availableBikes=4,availableDocks=15,latitude=40.69608941,location="",longitude=-73.97803415,stAddress1="Park Ave & St Edwards St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=19 1453498349000000000
    > citibikenyc,id=120,stationName=Lexington\ Ave\ &\ Classon\ Ave availableBikes=2,availableDocks=17,latitude=40.68676793,location="",longitude=-73.95928168,stAddress1="Lexington Ave & Classon Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=19 1453498326000000000
    > citibikenyc,id=127,stationName=Barrow\ St\ &\ Hudson\ St availableBikes=9,availableDocks=21,latitude=40.73172428,location="",longitude=-74.00674436,stAddress1="Barrow St & Hudson St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498214000000000
    > citibikenyc,id=128,stationName=MacDougal\ St\ &\ Prince\ St availableBikes=21,availableDocks=9,latitude=40.72710258,location="",longitude=-74.00297088,stAddress1="MacDougal St & Prince St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=30 1453498257000000000
    > citibikenyc,id=137,stationName=E\ 56\ St\ &\ Madison\ Ave availableBikes=30,availableDocks=15,latitude=40.761628,location="",longitude=-73.972924,stAddress1="E 56 St & Madison Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=46 1453498272000000000
    > citibikenyc,id=143,stationName=Clinton\ St\ &\ Joralemon\ St availableBikes=4,availableDocks=20,latitude=40.69239502,location="",longitude=-73.99337909,stAddress1="Clinton St & Joralemon St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=24 1453498135000000000
    > citibikenyc,id=144,stationName=Nassau\ St\ &\ Navy\ St availableBikes=12,availableDocks=5,latitude=40.69839895,location="",longitude=-73.98068914,stAddress1="Nassau St & Navy St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=19 1453498325000000000
    > citibikenyc,id=146,stationName=Hudson\ St\ &\ Reade\ St availableBikes=7,availableDocks=30,latitude=40.71625008,location="",longitude=-74.0091059,stAddress1="Hudson St & Reade St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498177000000000
    > citibikenyc,id=147,stationName=Greenwich\ St\ &\ Warren\ St availableBikes=15,availableDocks=18,latitude=40.71542197,location="",longitude=-74.01121978,stAddress1="Greenwich St & Warren St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=33 1453498325000000000
    > citibikenyc,id=150,stationName=E\ 2\ St\ &\ Avenue\ C availableBikes=2,availableDocks=29,latitude=40.7208736,location="",longitude=-73.98085795,stAddress1="E 2 St & Avenue C",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498264000000000
    > citibikenyc,id=151,stationName=Cleveland\ Pl\ &\ Spring\ St availableBikes=11,availableDocks=22,latitude=40.722103786686034,location="",longitude=-73.99724900722504,stAddress1="Cleveland Pl & Spring St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=33 1453498182000000000
    > citibikenyc,id=152,stationName=Warren\ St\ &\ Church\ St availableBikes=26,availableDocks=3,latitude=40.71473993,location="",longitude=-74.00910627,stAddress1="Warren St & Church St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=29 1453498204000000000
    > citibikenyc,id=153,stationName=E\ 40\ St\ &\ 5\ Ave availableBikes=17,availableDocks=36,latitude=40.752062307,location="",longitude=-73.9816324043,stAddress1="E 40 St & 5 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=55 1453498268000000000
    > citibikenyc,id=157,stationName=Henry\ St\ &\ Atlantic\ Ave availableBikes=6,availableDocks=16,latitude=40.69089272,location="",longitude=-73.99612349,stAddress1="Henry St & Atlantic Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498302000000000
    > citibikenyc,id=160,stationName=E\ 37\ St\ &\ Lexington\ Ave availableBikes=3,availableDocks=23,latitude=40.748238,location="",longitude=-73.978311,stAddress1="E 37 St & Lexington Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=26 1453498308000000000
    > citibikenyc,id=161,stationName=LaGuardia\ Pl\ &\ W\ 3\ St availableBikes=25,availableDocks=8,latitude=40.72917025,location="",longitude=-73.99810231,stAddress1="LaGuardia Pl & W 3 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=35 1453498314000000000
    > citibikenyc,id=164,stationName=E\ 47\ St\ &\ 2\ Ave availableBikes=10,availableDocks=37,latitude=40.75323098,location="",longitude=-73.97032517,stAddress1="E 47 St & 2 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=47 1453498169000000000
    > citibikenyc,id=167,stationName=E\ 39\ St\ &\ 3\ Ave availableBikes=23,availableDocks=22,latitude=40.7489006,location="",longitude=-73.97604882,stAddress1="E 39 St & 3 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=45 1453498210000000000
    > citibikenyc,id=168,stationName=W\ 18\ St\ &\ 6\ Ave availableBikes=34,availableDocks=11,latitude=40.73971301,location="",longitude=-73.99456405,stAddress1="W 18 St & 6 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=47 1453498205000000000
    > citibikenyc,id=173,stationName=Broadway\ &\ W\ 49\ St availableBikes=7,availableDocks=43,latitude=40.76068327096592,location="",longitude=-73.9845272898674,stAddress1="Broadway & W 49 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=51 1453498152000000000
    > citibikenyc,id=174,stationName=E\ 25\ St\ &\ 1\ Ave availableBikes=9,availableDocks=21,latitude=40.7381765,location="",longitude=-73.97738662,stAddress1="E 25 St & 1 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=30 1453498275000000000
    > citibikenyc,id=195,stationName=Liberty\ St\ &\ Broadway availableBikes=20,availableDocks=25,latitude=40.70905623,location="",longitude=-74.01043382,stAddress1="Liberty St & Broadway",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=45 1453498292000000000
    > citibikenyc,id=212,stationName=W\ 16\ St\ &\ The\ High\ Line availableBikes=3,availableDocks=24,latitude=40.74334935,location="",longitude=-74.00681753,stAddress1="W 16 St & The High Line",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=28 1453498353000000000
    > citibikenyc,id=216,stationName=Columbia\ Heights\ &\ Cranberry\ St availableBikes=10,availableDocks=13,latitude=40.70037867,location="",longitude=-73.99548059,stAddress1="Columbia Heights & Cranberry St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498252000000000
    > citibikenyc,id=217,stationName=Old\ Fulton\ St availableBikes=15,availableDocks=22,latitude=40.70277159,location="",longitude=-73.99383605,stAddress1="Old Fulton St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498206000000000
    > citibikenyc,id=223,stationName=W\ 13\ St\ &\ 7\ Ave availableBikes=10,availableDocks=21,latitude=40.73781509,location="",longitude=-73.99994661,stAddress1="W 13 St & 7 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=33 1453498186000000000
    > citibikenyc,id=224,stationName=Spruce\ St\ &\ Nassau\ St availableBikes=4,availableDocks=27,latitude=40.71146364,location="",longitude=-74.00552427,stAddress1="Spruce St & Nassau St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498267000000000
    > citibikenyc,id=225,stationName=W\ 14\ St\ &\ The\ High\ Line availableBikes=17,availableDocks=19,latitude=40.74195138,location="",longitude=-74.00803013,stAddress1="W 14 St & The High Line",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=37 1453498284000000000
    > citibikenyc,id=228,stationName=E\ 48\ St\ &\ 3\ Ave availableBikes=10,availableDocks=44,latitude=40.7546011026,location="",longitude=-73.971878855,stAddress1="E 48 St & 3 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=55 1453498149000000000
    > citibikenyc,id=229,stationName=Great\ Jones\ St availableBikes=17,availableDocks=1,latitude=40.72743423,location="",longitude=-73.99379025,stAddress1="Great Jones St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498367000000000
    > citibikenyc,id=232,stationName=Cadman\ Plaza\ E\ &\ Tillary\ St availableBikes=7,availableDocks=16,latitude=40.69597683,location="",longitude=-73.99014892,stAddress1="Cadman Plaza E & Tillary St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498295000000000
    > citibikenyc,id=233,stationName=Cadman\ Plaza\ W\ &\ Pierrepont\ St availableBikes=3,availableDocks=35,latitude=40.69475701363877,location="",longitude=-73.99052739143372,stAddress1="Cadman Plaza W & Pierrepont St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=38 1453498320000000000
    > citibikenyc,id=236,stationName=St\ Marks\ Pl\ &\ 2\ Ave availableBikes=6,availableDocks=33,latitude=40.7284186,location="",longitude=-73.98713956,stAddress1="St Marks Pl & 2 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498305000000000
    > citibikenyc,id=237,stationName=E\ 11\ St\ &\ 2\ Ave availableBikes=1,availableDocks=37,latitude=40.73047309,location="",longitude=-73.98672378,stAddress1="E 11 St & 2 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498150000000000
    > citibikenyc,id=238,stationName=Bank\ St\ &\ Washington\ St availableBikes=16,availableDocks=14,latitude=40.7361967,location="",longitude=-74.00859207,stAddress1="Bank St & Washington St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498349000000000
    > citibikenyc,id=239,stationName=Willoughby\ St\ &\ Fleet\ St availableBikes=13,availableDocks=17,latitude=40.69196566,location="",longitude=-73.9813018,stAddress1="Willoughby St & Fleet St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498276000000000
    > citibikenyc,id=241,stationName=DeKalb\ Ave\ &\ S\ Portland\ Ave availableBikes=3,availableDocks=19,latitude=40.68981035,location="",longitude=-73.97493121,stAddress1="DeKalb Ave & S Portland Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498336000000000
    > citibikenyc,id=242,stationName=Carlton\ Ave\ &\ Flushing\ Ave availableBikes=4,availableDocks=19,latitude=40.697787,location="",longitude=-73.973736,stAddress1="Carlton Ave & Flushing Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498354000000000
    > citibikenyc,id=243,stationName=Fulton\ St\ &\ Rockwell\ Pl availableBikes=26,availableDocks=4,latitude=40.688226,location="",longitude=-73.979382,stAddress1="Fulton St & Rockwell Pl",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498348000000000
    > citibikenyc,id=244,stationName=Willoughby\ Ave\ &\ Hall\ St availableBikes=5,availableDocks=26,latitude=40.69196035,location="",longitude=-73.96536851,stAddress1="Willoughby Ave & Hall St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498176000000000
    > citibikenyc,id=245,stationName=Myrtle\ Ave\ &\ St\ Edwards\ St availableBikes=7,availableDocks=16,latitude=40.69327018,location="",longitude=-73.97703874,stAddress1="Myrtle Ave & St Edwards St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498316000000000
    > citibikenyc,id=247,stationName=Perry\ St\ &\ Bleecker\ St availableBikes=11,availableDocks=9,latitude=40.73535398,location="",longitude=-74.00483091,stAddress1="Perry St & Bleecker St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=20 1453498313000000000
    > citibikenyc,id=248,stationName=Laight\ St\ &\ Hudson\ St availableBikes=12,availableDocks=10,latitude=40.72185379,location="",longitude=-74.00771779,stAddress1="Laight St & Hudson St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498358000000000
    > citibikenyc,id=249,stationName=Harrison\ St\ &\ Hudson\ St availableBikes=25,availableDocks=2,latitude=40.71870987,location="",longitude=-74.0090009,stAddress1="Harrison St & Hudson St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498137000000000
    > citibikenyc,id=250,stationName=Lafayette\ St\ &\ Jersey\ St availableBikes=35,availableDocks=2,latitude=40.72456089,location="",longitude=-73.99565293,stAddress1="Lafayette St & Jersey St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=40 1453498151000000000
    > citibikenyc,id=251,stationName=Mott\ St\ &\ Prince\ St availableBikes=2,availableDocks=23,latitude=40.72317958,location="",longitude=-73.99480012,stAddress1="Mott St & Prince St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498339000000000
    > citibikenyc,id=252,stationName=MacDougal\ St\ &\ Washington\ Sq availableBikes=2,availableDocks=31,latitude=40.73226398,location="",longitude=-73.99852205,stAddress1="MacDougal St & Washington Sq",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=33 1453498298000000000
    > citibikenyc,id=253,stationName=W\ 13\ St\ &\ 5\ Ave availableBikes=13,availableDocks=39,latitude=40.73543934,location="",longitude=-73.99453948,stAddress1="W 13 St & 5 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=55 1453498237000000000
    > citibikenyc,id=254,stationName=W\ 11\ St\ &\ 6\ Ave availableBikes=6,availableDocks=25,latitude=40.73532427,location="",longitude=-73.99800419,stAddress1="W 11 St & 6 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498227000000000
    > citibikenyc,id=257,stationName=Lispenard\ St\ &\ Broadway availableBikes=33,availableDocks=4,latitude=40.71939226,location="",longitude=-74.00247214,stAddress1="Lispenard St & Broadway",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498332000000000
    > citibikenyc,id=258,stationName=DeKalb\ Ave\ &\ Vanderbilt\ Ave availableBikes=0,availableDocks=23,latitude=40.68940747,location="",longitude=-73.96885458,stAddress1="DeKalb Ave & Vanderbilt Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498325000000000
    > citibikenyc,id=259,stationName=South\ St\ &\ Whitehall\ St availableBikes=35,availableDocks=4,latitude=40.70122128,location="",longitude=-74.01234218,stAddress1="South St & Whitehall St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=39 1453498272000000000
    > citibikenyc,id=260,stationName=Broad\ St\ &\ Bridge\ St availableBikes=25,availableDocks=10,latitude=40.70365182,location="",longitude=-74.01167797,stAddress1="Broad St & Bridge St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=35 1453498224000000000
    > citibikenyc,id=261,stationName=Johnson\ St\ &\ Gold\ St availableBikes=13,availableDocks=14,latitude=40.69474881,location="",longitude=-73.98362464,stAddress1="Johnson St & Gold St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498252000000000
    > citibikenyc,id=262,stationName=Washington\ Park availableBikes=1,availableDocks=23,latitude=40.6917823,location="",longitude=-73.9737299,stAddress1="Washington Park",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=24 1453498174000000000
    > citibikenyc,id=263,stationName=Elizabeth\ St\ &\ Hester\ St availableBikes=0,availableDocks=31,latitude=40.71729,location="",longitude=-73.996375,stAddress1="Elizabeth St & Hester St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498362000000000
    > citibikenyc,id=264,stationName=Maiden\ Ln\ &\ Pearl\ St availableBikes=24,availableDocks=3,latitude=40.70706456,location="",longitude=-74.00731853,stAddress1="Maiden Ln & Pearl St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498339000000000
    > citibikenyc,id=265,stationName=Stanton\ St\ &\ Chrystie\ St availableBikes=10,availableDocks=24,latitude=40.72229346,location="",longitude=-73.99147535,stAddress1="Stanton St & Chrystie St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=35 1453498347000000000
    > citibikenyc,id=266,stationName=Avenue\ D\ &\ E\ 8\ St availableBikes=2,availableDocks=22,latitude=40.72368361,location="",longitude=-73.97574813,stAddress1="Avenue D & E 8 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=24 1453498344000000000
    > citibikenyc,id=267,stationName=Broadway\ &\ W\ 36\ St availableBikes=1,availableDocks=56,latitude=40.75097711,location="",longitude=-73.98765428,stAddress1="Broadway & W 36 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=57 1453498347000000000
    > citibikenyc,id=268,stationName=Howard\ St\ &\ Centre\ St availableBikes=25,availableDocks=2,latitude=40.71910537,location="",longitude=-73.99973337,stAddress1="Howard St & Centre St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498265000000000
    > citibikenyc,id=270,stationName=Adelphi\ St\ &\ Myrtle\ Ave availableBikes=5,availableDocks=17,latitude=40.69308257,location="",longitude=-73.97178913,stAddress1="Adelphi St & Myrtle Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=23 1453498158000000000
    > citibikenyc,id=274,stationName=Lafayette\ Ave\ &\ Fort\ Greene\ Pl availableBikes=20,availableDocks=11,latitude=40.68691865,location="",longitude=-73.976682,stAddress1="Lafayette Ave & Fort Greene Pl",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498225000000000
    > citibikenyc,id=275,stationName=Washington\ Ave\ &\ Greene\ Ave availableBikes=3,availableDocks=16,latitude=40.68650065,location="",longitude=-73.96563307,stAddress1="Washington Ave & Greene Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=19 1453498311000000000
    > citibikenyc,id=276,stationName=Duane\ St\ &\ Greenwich\ St availableBikes=22,availableDocks=2,latitude=40.71748752,location="",longitude=-74.0104554,stAddress1="Duane St & Greenwich St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=25 1453498257000000000
    > citibikenyc,id=278,stationName=Concord\ St\ &\ Bridge\ St availableBikes=10,availableDocks=8,latitude=40.69766564,location="",longitude=-73.98476437,stAddress1="Concord St & Bridge St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=19 1453498277000000000
    > citibikenyc,id=279,stationName=Peck\ Slip\ &\ Front\ St availableBikes=23,availableDocks=13,latitude=40.707873,location="",longitude=-74.00167,stAddress1="Peck Slip & Front St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=36 1453498162000000000
    > citibikenyc,id=280,stationName=E\ 10\ St\ &\ 5\ Ave availableBikes=20,availableDocks=10,latitude=40.73331967,location="",longitude=-73.99510132,stAddress1="E 10 St & 5 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=31 1453498357000000000
    > citibikenyc,id=281,stationName=Grand\ Army\ Plaza\ &\ Central\ Park\ S availableBikes=26,availableDocks=33,latitude=40.7643971,location="",longitude=-73.97371465,stAddress1="Grand Army Plaza & Central Park S",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=59 1453498195000000000
    > citibikenyc,id=282,stationName=Kent\ Ave\ &\ S\ 11\ St availableBikes=4,availableDocks=23,latitude=40.70827295,location="",longitude=-73.96834101,stAddress1="Kent Ave & S 11 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498268000000000
2021-01-27T19:47:01Z D! [agent] Stopping service inputs
2021-01-27T19:47:01Z D! [agent] Input channel closed
2021-01-27T19:47:01Z D! [agent] Stopped Successfully
    > citibikenyc,id=284,stationName=Greenwich\ Ave\ &\ 8\ Ave availableBikes=26,availableDocks=16,latitude=40.7390169121,location="",longitude=-74.0026376103,stAddress1="Greenwich Ave & 8 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=43 1453498272000000000
    > citibikenyc,id=285,stationName=Broadway\ &\ E\ 14\ St availableBikes=10,availableDocks=36,latitude=40.73454567,location="",longitude=-73.99074142,stAddress1="Broadway & E 14 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=47 1453498291000000000
    > citibikenyc,id=289,stationName=Monroe\ St\ &\ Classon\ Ave availableBikes=6,availableDocks=13,latitude=40.6845683,location="",longitude=-73.95881081,stAddress1="Monroe St & Classon Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=19 1453498206000000000
    > citibikenyc,id=291,stationName=Madison\ St\ &\ Montgomery\ St availableBikes=0,availableDocks=20,latitude=40.713126,location="",longitude=-73.984844,stAddress1="Madison St & Montgomery St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=20 1453498155000000000
    > citibikenyc,id=293,stationName=Lafayette\ St\ &\ E\ 8\ St availableBikes=10,availableDocks=42,latitude=40.73028666,location="",longitude=-73.9907647,stAddress1="Lafayette St & E 8 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=55 1453498339000000000
    > citibikenyc,id=295,stationName=Pike\ St\ &\ E\ Broadway availableBikes=0,availableDocks=24,latitude=40.71406667,location="",longitude=-73.99293911,stAddress1="Pike St & E Broadway",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=24 1453498145000000000
    > citibikenyc,id=296,stationName=Division\ St\ &\ Bowery availableBikes=27,availableDocks=6,latitude=40.71413089,location="",longitude=-73.9970468,stAddress1="Division St & Bowery",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=35 1453498330000000000
    > citibikenyc,id=297,stationName=E\ 15\ St\ &\ 3\ Ave availableBikes=6,availableDocks=21,latitude=40.734232,location="",longitude=-73.986923,stAddress1="E 15 St & 3 Ave",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=27 1453498143000000000
    > citibikenyc,id=298,stationName=3\ Ave\ &\ Schermerhorn\ St availableBikes=21,availableDocks=14,latitude=40.68683208,location="",longitude=-73.9796772,stAddress1="3 Ave & Schermerhorn St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=35 1453498279000000000
    > citibikenyc,id=300,stationName=Shevchenko\ Pl\ &\ E\ 7\ St availableBikes=11,availableDocks=42,latitude=40.728145,location="",longitude=-73.990214,stAddress1="Shevchenko Pl & E 7 St",stAddress2="",statusKey=1,statusValue="In Service",totalDocks=55 1453498366000000000
without -test
2021-01-27T19:52:50Z I! Starting Telegraf 1.17.0
2021-01-27T19:52:50Z I! Loaded inputs: http
2021-01-27T19:52:50Z I! Loaded aggregators:
2021-01-27T19:52:50Z I! Loaded processors:
2021-01-27T19:52:50Z I! Loaded outputs: influxdb_v2
2021-01-27T19:52:50Z I! Tags enabled: host=Music4Lox
2021-01-27T19:52:50Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"Music4Lox", Flush Interval:10s
2021-01-27T19:52:50Z D! [agent] Initializing plugins
2021-01-27T19:52:50Z D! [agent] Connecting outputs
2021-01-27T19:52:50Z D! [agent] Attempting connection to [outputs.influxdb_v2]
2021-01-27T19:52:50Z D! [agent] Successfully connected to outputs.influxdb_v2
2021-01-27T19:52:50Z D! [agent] Starting service inputs
2021-01-27T19:53:00Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 1000 metrics
2021-01-27T19:53:00Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 27.572175ms
2021-01-27T19:53:00Z D! [outputs.influxdb_v2] Buffer fullness: 409 / 1000 metrics
2021-01-27T19:53:01Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 17.516596ms
2021-01-27T19:53:01Z D! [outputs.influxdb_v2] Buffer fullness: 309 / 1000 metrics
2021-01-27T19:53:10Z W! [agent] ["outputs.influxdb_v2"] did not complete within its flush interval
2021-01-27T19:53:10Z D! [outputs.influxdb_v2] Buffer fullness: 818 / 1000 metrics
2021-01-27T19:53:10Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 64.719596ms
2021-01-27T19:53:10Z D! [outputs.influxdb_v2] Buffer fullness: 718 / 1000 metrics
2021-01-27T19:53:10Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 22.794779ms
2021-01-27T19:53:10Z D! [outputs.influxdb_v2] Buffer fullness: 618 / 1000 metrics
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 25.233479ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 18.579285ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 26.830332ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 18.399968ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 19.821066ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 21.99271ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 18 metrics in 11.573632ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 1000 metrics
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 30.043501ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Buffer fullness: 282 / 1000 metrics
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 17.783327ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Buffer fullness: 309 / 1000 metrics
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 15.81829ms
2021-01-27T19:53:20Z D! [outputs.influxdb_v2] Buffer fullness: 209 / 1000 metrics
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 30.99005ms
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 19.623412ms
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Wrote batch of 39 metrics in 9.929453ms
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Buffer fullness: 59 / 1000 metrics
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Wrote batch of 72 metrics in 13.45373ms
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Buffer fullness: 395 / 1000 metrics
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 27.63799ms
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Buffer fullness: 307 / 1000 metrics
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 18.889917ms
2021-01-27T19:53:30Z D! [outputs.influxdb_v2] Buffer fullness: 207 / 1000 metrics
^C2021-01-27T19:53:32Z D! [agent] Stopping service inputs
2021-01-27T19:53:32Z D! [agent] Input channel closed
2021-01-27T19:53:32Z I! [agent] Hang on, flushing any cached metrics before shutdown
2021-01-27T19:53:32Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 18.772665ms
2021-01-27T19:53:33Z D! [outputs.influxdb_v2] Wrote batch of 100 metrics in 16.73035ms
2021-01-27T19:53:33Z D! [outputs.influxdb_v2] Wrote batch of 7 metrics in 6.532704ms
2021-01-27T19:53:33Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 1000 metrics
2021-01-27T19:53:33Z D! [agent] Stopped Successfully
Thank you!
Greetings,
Jan
Did you ever figure this out? I’m having this exact problem. Thanks!
