I am using this telegraf helm chart:
It’s configured with a values.yaml file that defines the telegraf.conf (using yaml). Here is the config section of my values.yaml:
config:
agent:
interval: "10s"
round_interval: true
metric_batch_size: 1000
metric_buffer_limit: 10000
collection_jitter: "0s"
flush_interval: "10s"
flush_jitter: "0s"
precision: ""
debug: false
quiet: false
logfile: ""
hostname: "$HOSTNAME"
omit_hostname: false
processors:
- enum:
mapping:
field: "status"
dest: "status_code"
value_mappings:
healthy: 1
problem: 2
critical: 3
outputs:
- influxdb:
urls:
- "http://endpoint:8429"
database: "telegraf"
inputs:
- statsd:
service_address: ":8125"
percentiles:
- 50
- 95
- 99
metric_separator: "_"
allowed_pending_messages: 10000
percentile_limit: 1000
- opcua:
endpoint: "opc.tcp://endpoint:46010"
connect_timeout: "10s"
request_timeout: "5s"
security_policy: "None"
security_mode: "None"
auth_method: "Anonymous"
nodes:
- name: "ConcentrationNH3"
namespace: "2"
identifier_type: "s"
identifier: "ConcentrationNH3"
- name: "ConcentrationN2"
namespace: "2"
identifier: "ConcentrationN2"
- name: "ConcentrationH2"
namespace: "2"
identifier: "ConcentrationH2"
- name: "Pressure"
namespace: "2"
identifier: "Pressure"
Specifically, look at the opcua plugin configuration:
- opcua:
When I try run telegraf with this configuration I get this error:
2024-10-09T02:52:08Z I! Loading config: /etc/telegraf/telegraf.conf
2024-10-09T02:52:08Z E! loading config file /etc/telegraf/telegraf.conf failed: plugin inputs.opcua: line 32: configuration specified the fields ["request_timeout" "security_mode" "security_policy"], but they were not used. This is either a typo or this config option does not exist in this version.
Which is odd because those field should definitely exist and I need to set them to None to get my setup working.
I removed those fields and as able to boot telegraf. Then I manually edited the telegraf.conf file to re-include those fields and rebooted the pod. That worked with no issue so I know the fields are valid.
My question is this: Why can I not set the fields [“request_timeout” “security_mode” “security_policy”] in the helm chart values.yaml, but I can set them manually in the telegraf.conf?
I am guessing this is some sort of templating issue, or some problem converting yaml to toml.
Can I sidestep the helm chart’s values file and directly mount in my config file as a configmap? Any other suggestions?
EDIT:
I also wanted to include the errors I see without the security_mode and security_policy values set:
2024-10-09T21:47:40Z W! [inputs.opcua] Failed to load certificate: open /etc/telegraf/cert.pem: no such file or directory
2024-10-09T21:47:40Z E! [inputs.opcua] Error in plugin: connect failed: error in Client Connection: opcua: invalid channel config: Security policy 'http://opcfoundation.org/UA/SecurityPolicy#Aes256_Sha256_RsaPss' requires a private key
2024-10-09T21:47:50Z E! [inputs.opcua] Error in plugin: not connected, in state "Connecting"
This is why I need to be able to set those values.
