Were you able to resolve your issue? Looking through the YAML I see an empty “name” key under serviceAccount, and then two “name” keys under inputs. I don’t think the duplication should matter, but if you only run with one does it work?
it has been resolved with the new development made
influxdata:master ← bonitoo-io:fix/telegraf-config-v2-templates
opened 01:25PM - 16 Mar 22 UTC
This PR adds alternative config templates for `aggregators`, `processors`, `inpu… ts` and `outputs`.
There have been a few issues so far where existing templates fail to render valid configuration elements (#433, #429, #375, #119, #111 etc). Existing templates are written with nesting that attempts to match generated output (especially for `inputs`), but it is insufficient and becomes difficult to maintain.
The new set of templates use one common recursive template that handles nesting without limits. The feature can be activated by setting `tplVersion` to `2` (either via `--set` helm option or as an entry in values file).
Config examples from the above mentioned issues are all together in `charts/telegraf/ci/complex-values.yaml` file and have been tested. The resulting [telegraf.conf](https://github.com/influxdata/helm-charts/files/8262347/telegraf.conf.txt) is valid and Telegraf runs with it.
Hopefully the new templates will support greater variety of yaml configs than existing templates. It may reduce the need to have an option to specify raw config (#358). But why not have both.
There is also a small amendment to workflow in this PR: after charts are tested (with success), logs are checked for messages that represent severe errors. In case of telegraf chart, when config file is invalid and Telegraf actually fails to start, `ct install` check result is success nevertheless.
